Factory Radio Replacement
Is the 95-8202 the one that replaces the factory brackets? I have a non JBL SR5 that currently has a single DIN Pioneer that was installed before I bought the truck. I haven’t taken it apart yet, but based on what I’ve read on this forum, I will need to source factory brackets when I buy a double DIN, but with certain kits, I know you don’t need them. For example, I just installed a Sony XAV-AX1000 in my daughter’s ‘03 Camry (which had JBL), and used Metra 99-8231, which had its own plastic brackets that clipped onto the front filler piece. It installed perfectly, but was a real pain because the factory bracket screws wouldn’t work with the Sony, and the screws that came with the kit wouldn’t either. I had to source some different self tapping screws to make it work, which delayed the install a bit, but then it dropped in and fit perfectly. Sorry for the long story, but I just want to be sure I don’t waste time and money ordering factory brackets only to find out that the install kit doesn’t need them.
Edit: never mind, I just got my answer above. I guess I should’ve read the whole thread before asking about the brackets.
99-8300 kit for 25-30 bucks, or source the factory radio brackets to use the 95-8202.
Anyone know where parking brake wiring is? Trying to finish my install for AA and DVD
I just grounded mine, it just bypasses the whole parking brake switch needed to be depressed to play. It’s the lime green wire rolled up and grounded the the bolt on the left side of the face.
Recently installed a Pioneer AVH-2550NEX DVD unit and grounding that light green parking brake wire did not work. Ended up purchasing this DIY Parking Brake Bypass from ebay to get the override to work correctly. Super easy to install while installing a new head unit...
DIYBypass Parking Brake Bypass Fits ALL AVH Pioneer Override DVD Video Lockout | eBay
How do like the AVH-2550NEX? That is the unit I’m close to pulling the trigger on. It was between that and the Sony AX210sxm but I already have an xm tuner and antenna now and there’s a lot more reviews on the Pioneer. I think I’m pretty set on the Pioneer 2550. Was considering ordering today or next few.
Hmmmm, interesting and good to know on the newer units, mine works fine grounding the PB wire but is an older unit. Guess I’ll have to order a bypass myself then.
I am well on my way to a new radio myself! I was toying with the idea of the 10.2 inch Android radio on Amazon after doing some testing with tethering to my LG tablet. Ultimately I decided to go with a trusted brand with warranty and customer support from Crutchfield (I am not affiliated with them, used them many times and love their dedication to service!)
Here is what my LG tablet looked like, worked well but was ultimately doomed by WiFi threatening and poor GPS reception:
I ended up choosing Kenwood Excelon DMX706S along with iDatalink Maestro RR Interface Module and iDatalink HRN-RR-TO1 Factory Integration Adapter. Supports Apple CarPlay or Android Auto as well as ties into factory ECU and Retains Steering Wheel controls:
