Yesterday I strapped my core into my prius and made the pilgrimage over the Sierras to Yota1 Performance to pick up the new trans. Cool little shop, they appeared to have plenty of business.
Prior to my trip I had one more conversation with Nick finalizing my installation plans. He suggested that I not use an external filter, magnafine or otherwise. His comments as I recall were only clutch material should be floating around and would rather have that than flow restriction. Considering my transmission finally failed after replacing my filter (though I had symptoms before it), I'm happy enough to avoid the introduction of additional parts in the system and fluid restrictions. He also instructed for initial fill to target 2qts below specification, fill half of that amount, tap the starter to pump the fluid, fill the other half, bring transmission to temperature and fine tune the level. I confirmed with Nick that I'll be running a Hayden 699 in series with the new radiator mounted similarly to Tim's recent video, though I still haven't decided on the exact mounting or plumbing. Tim has it mounted with the ports on the side I'm assuming for optimal plumbing, but I haven't found any info from Hayden showing that orientation or mention of it being supported by their valving system, only "bi-directional flow". I'll probably call them. Cooler research:
https://www.haydenauto.com/media/9055/bypass-transmission-oil-cooler_flyer_2022.pdf
Ecatalog has a video that references this patent showing the bypass valve system
US6253837B1 - By-pass values for heat exchanger
- Google Patents
I've finished most of my prep work. I rebuilt the starter, including cleaning and regreasing the motor side of the assembly, replacing the solenoid contacts, the gasket, the breathers I broke (might be worth replacing regardless if you're in this deep, mine were quite brittle), and the plunger. I didn't replace or measure the brushes or brush springs, but all looked well and my starter has been functioning well. I used some super glue on a degraded terminal cover between the solenoid and motor as I couldn't find an OEM replacement. Parts list:
28226-54340 STARTER KIT, BATTERY TERMINAL
28226-72010 STARTER KIT, MOTOR TERMINAL
28235-54380 PLUNGER, MAGNET SWITCH
28175-54380 GASKET; PACKING
2x 28199-74110 PRORECTER, DUST STAR
2x 90099-14064 O-Ring (if you dissasemble the motor side, mine crumbled immediately)
I replaced the rear main seal. It wasn't very difficult, but you may need a helper on the front of the engine or a pulley holder tool on the flex plate to torque the flex plate down. Torque up slowly per the fsm. Also red loctite 271 (three bond 1324 or equivalent). I didn't seriously consider replacing my flex plate, I'd rather gamble on the one I have.
90311-A0027 Engine Crankshaft Seal (Rear)
three bond 1324 or equivalent (
Toyota Adhesive & Sealant Cross Reference Chart - YotaTech Forums)
I replaced the external oil seals on the transfer case. I found these seals to be more challenging to install and remove. Considering the transfer case is easier to access if necessary, I wouldn't necessarily suggest messing with these (besides the fill/drain plug crush washers) if you have no signs of leakage. I'm going to reinstall a new set of the the shifter shaft seals tomorrow because I'm not happy with their insertion depth. A pry bar against the flange studs and impact gun spun the staked nut without issue. FSM prescribes moly grease for most of the seal lips. Part numbers:
2x 90179-22016 Companion Flange Nut
90311-41012 Front Transfer Case output shaft seal
2x 90312-23001 Companion flange seal
2x 90430-18008 Gasket Drain/Fill plugs
90311-40021 Transfer Case Input Shaft Seal
2x 90311-15008 Transfer Case Shift Shaft Seal (4x in my case)
90311-41020 Transfer Case Extension Housing Seal (Front)
MCTM-523 Marlin Crawler Heavy Duty Shifter Seat
I suggest you remove the shifter as an assembly with the top plate to avoid dropping shifter seat fragments into the transfer case like i did. If you do and have the same transfer case as me:
36108-35060 DEFLECTOR SUB-ASSY
36345-35050 GASKET, TRFER CONT S
Remember to remove all the brackets, shifter linkage, neutral position switch, breather hose, and mounting hardware from your core. I also needed an inspection plate and hardware on the transfer case side but I don't believe all A340F's have this. I was worried today i was missing an alignment dowel but I think/hope they're all present, 2 on the engine and 2 on the new transmission for the transfer case.
I also tackled some surface rust on the crossmembers and their mounts. Some quick wire brushing, VHT rust convertor primer, and some enamel. So far so good on this 23 year old rust prone frame, I'd like to keep it that way.
Does anyone know the part number for the retaining washer and gasket for the neutral position switch? My local dealer couldn't find them for sale seperately and I couldn't find them online despite the FSM suggesting the retaining washer needs replacement. My retaining washer was the only thing holding the nut on, but the switch took a scary amount of force to pry off. The switch part number I believe is 84540-30270. I noted from Tim's video to make sure you install this before the fluid lines.
Friendly reminder for those tackling this job to stay organized, take lots of pictures, tag/bag bolts and brackets. I'm already wishing I did better, but am thankful I didn't do worse.
