I have a spacer kit that I want to put in for the time being. I will do a full suspension next summer with new rims.
What spacers are you running and how do you like it ? Im a little skeptical . I Actually have 2 different kits. I have a 2.5" 6pc DS kit with top out and pre load for front and a 1.5 in back spacer.
I also have a slightly used CF 2"/1" from my friend.
I do go off road but nothing heavy like rock crawling , but it is low speed crawling around . Would going with the lower CF kit be less hard on the shocks and cv's ect....
~or~
would the DS kit be better because of the preload spacer / top out combo ?
I will be running stock size tires , BUT after market AT tires. Maybe Firestones or Duratrac's .
Thank you
Mike
Thank you David.
Do you know anything about diff drop kits like Toytec has ? When I do the (suspension lift) next year I'm going with and OME set up and wondered if I'll need them then otherwise I'll put them in when I do the spacer lift.
Mike
Please excuse my mechanical ignorance about this topic.
Im rethinking my lift options. Are CO's and rear springs easier to install than spacers. The spacers i have I will have to pull the spring with a compressor to install longer studs and put it back together , the rears are pull out the springs and put the spacers in.
If I buy CO's and rear springs would the (self) install be easier ? Seems to me like a remove and put in the new crap and just get an alignment or is there more to it than that ?
Mike~
Anyone have problems with the install ? or after the fact ? My goal is to have better on and off road handling. I figure this install will be easier than spacers where I have to pull the CO apart to put longer studs in anyway , so it should go smoother.
I'm doing a mild lift and putting the CO's at 2.5" (which they say is the factory setting from Toytec ) I'm gonna throw the diff drop kit in since it's only $30. In the rear I'm gonna do SAW rear 1.5" coils and Bilstein 5100 series shocks.
Anyone have a pic of this set up and the 5th gen ?
You still can/will rub a little depending on the brand/type of tire that is 285/70/17. Most tire manufacturer specs can be a little different and depending how prolific the outside lugs are which are what do the rubbing.
Rather then cut the liner off to prevent the rubbing. Do what's referred to as pulling the front part of the liner forward.
Elongate the 2 bottom holes,or maybe there's 3,in the liner by taking it loose,pushing it forward as far as possible and carefully making new holes just in the liner. I used an exacto knife but the abs plastic is kind of hard to work with. My suggestion is to put the new holes in with and Dremel with a small round ball or equivalent .Put the bolts back in and tighten. Wala.....You now have 1/2" -1" more clearance so your tire doesn't rub in the front.
Then when you have it aligned ,take it to a shop that knows what they are doing and have them align it so the wheel is forward(max caster).You may not get max caster with the stock UCA and one of the main reasons people use aftermarket ones . This will make it so it won't rub in the back ,on the mud flap in my case. Here is a pic I just took at the bottom front drivers side to try and give you an idea of what I'm talking about. See the gap I created where I moved it forward.That gets you an extra 1/2" or so of clearance and no rubbing. We need somebody to do a better write-up on this when/if they do it...hint sp8ball/antman!!!My bolts just look different because I used Aircraft stainless bolts/washer/nuts. I think it will make more sense when you get up under there and take the fasteners out and see that the liner can be pushed forward! It's a very simple mod.This is an old pic and of a TE liner. A SR5/Limited liner will be a little different to do, but the same principal to move the liner forward.
Has anyone described how to do this with a little more detail. This is making me feel really stupid because I'm just not seeing it.
