Fender Flares Coming Off
Mason
What is the best way to reattach the OEM fender flares back onto the vehicle? Passenger side is coming off the body.
Same question as [MENTION=43936]zcruiser[/MENTION] asked: have the holes in the flairs (bolts go through the holes in the flairs to the body) been enlarged in anyway?
As long as the bolts aren't stripped or missing you can you can probably use fender washers between the bolts and flairs to hold them down.
If your flairs have been distorted in anyway, as in they no longer follow the contour of the fenders, then you may have to reform them carefully with heat or replace them
On the front, They hold on with clips and a type of side molding tape that I don't think you can buy from Toyota. I used some 3M side molding tape with new clips. There was still a small gap, but no big deal. It is hard to get it perfect once they deform a little. The rear is just clips....
ghengiskhan
