I'll never get tired of wrenching on this thing, but I'm really losing my patience for not having my own garage where I can do tedious projects at my leisure, lol! Yet another "shouldn't take this long, but it is" weekend project: LCA bushings.
I mostly followed the "Part 1" guide from Timmy on YT, but some of my steps weren't so easy as his. First, it didn't dawn on me until the second side that I needed to remove my diff drop spacers in order to lift it out of the way of the horizontal bolt on the steering rack, but the passenger side wasn't too picky with it still being in anyway; just a little tight. Second, I didn't bother to preheat the bushing that was about to be pushed out with a 6-ton bottle jack, which most likely would've require less force to get it to break loose. Not so bad so far, but I don't think I got one of the bushings all the way by utilizing Timmy's channel-lock trick; it just bent the outer ring before I realized that I could use the ball joint service kit I have for it all to work perfectly on that front face side - 41mm wrench works awesome on the back.
The first major issue came when I went to put the passenger LCA back in. I could get the outer washer in with one side but there no room at all for the other. I messed with it longer that it took to do everything else up to that point and then called it quits after a few hours. After some rest, I had an epiphany that I could just ratchet one side to compress the bushing and then wedge the other sides washer in with the help of a pry bar. Success!
Now, the other side...
I thought I was on easy street! I had the rack out of the way, the LCA came out super quick, and then onto pressing out the old bushing... womp, womp. I could literally see the LCA flexing with the amount of force I was putting on it with the jack and no matter how much heat I applied (the internals were literally on fire at one point) it would not go! I tried to use the ball joint service kit, but that damned outer bushing lip was in the way! I tried to cut and smash it out, but the arm made it near impossible to do about half of it. Well, I needed to buy a reciprocating saw anyway, so off to HD I went!
Two drill bits and a whole lot of swearing later, this is what was left of that finnicky bushing. The crazy part was that once I cut two slits into the metal sleeve it pulled right out! All-in-all, I would not try this again without being able to do it on my own time in my own garage. I was at my company shop until 2 am THIS MORNING putting it all back together and cleaning up... and I still had to take the company truck home because the alignment was all wonky with the addition of Sonoran Steel 1/4" strut spacers done at the same time.
Speaking of the spacers...
They were supposed to give me about 1/2" of additional lift up front, which
should've still kept about a 1" rake. At the moment, all four fenders at ~39" from the ground, which seems odd. I read a post on here about someone questioning if the UCA bushings could add a lift, with the general consensus was that is could offer a slight lift because of the droop you'd get with bad old bushings, which I had, but this seems a little excessive. If anyone has input then it'd be appreciated! Well, off for the alignment!
