Finally Tundra 13WL brake upgrade...56k beware
Shonuup
Look what came in the mail!
I ordered the 199mm S13WE but after doing research, the 231mm 13WL seemed to be a better replacement.
TRD stickers
Stickers clear-coated on.
The old setup...You can see my Downey headers...oh yeah!
sorry camera phone...
remove the two bolts holding the caliper...
Look how much worn down the stock rotors were. The new Tundra rotors are way beefier.
Installed...
A close up.
The stopping power is amazing. After heavy braking there is no more brake fade.
dam schon nice mods to your truck
where you order that stuff and what kinda damage it do?(money wise)
Nice... I'm also curious as to the $$ you put into the tundra brake upgrade. Good bye warped rotors and hello dashboard as ya slam on them brakes. :bigok:
DAbrakes
Screw da BRAKES lemme buy your RIMS!!
VERY NICE!
But yeah, your setup looked so EZ!!!
Was it less than $500?
Also, what made you go with slotted/drilled? I thought everyone said stay away from that combo.
Now im confused.
I need some rotors BAD!! Dashboard is taking a beating so bad!!!
oh well...
I would'a just went with slotted and avoided any kind of crossdrilled since within 30k miles they will crack and I've yet to see a set not do that. Still a great setup over stock as 4Runners brakes are pretty weak.
very nice look
those look outstanding.
Those calipers would not fit behind a 16 inch rim is that fair to say?
nice pictures thanks for posting them up
another one for the Tundra/Sequoia upgrade! I believe 16" after market wheel will fit. On stock wheels you can run wheel spacer or grind the inside down.
i am running on 16" Egale wheels with wheel spacer, since my tires blew out. This is how i know it fitted.
how much did you get your set for?
here is my break down for my set.
$130 for rotors and pads.
$100 for front and rear calipers for 06 Sequoia. (off ebay)
$30 for fluids (brake fluids and a Big Mac meal)
2 hrs of your life
equal to $260 and a brake well worth it.
I thought there was a Tundra brake that fits within the stock 16" alloy rims. Is it the standard Tundra brakes, and not the TRD ones?
CO_FlyFisher said:
I thought there was a Tundra brake that fits wihtin the stock 16" alloy rims. Is it the standard Tundra brakes, and not the TRD ones?
Yes, the earlier Tundra calipers fit (199mm).
OP - Nice set of brakes. Hope it works out for you. IMO, a little overkill. I would've just went with the stock blank rotor set up, but at least they look nice.
BTW, does anybody even have 56k anymore? 56k warnings don't seem applicable now-a-days. :p
2 hrs of your life
Did you say that you did a sequoia rear brake upgrade??
Here's my break down...
$130 on the D/S rotors (pair)
$260 Tundra 13WL Calipers
$30 Powder coated
$60 Hawk pads
As far as drilled vs slotted... i've had the D/S on all my vehicles and never had a problem with cracking...so never thought much of it.
56K...ya i know, it just sounded good. like...LOOK OUT!! :)
and a lot of hand cleaner...
Ebay is your friend. Just take your time on putting it together. took me over 3 month to win a set. But if your stock breaks are still good then way rush.
13WL - Sequoia Calipers
Ok guys. It is doable.
I just bought some 2001 Sequoia front calipers.
$50 each. They came with pads and shims.
Why? I do not know.
But I think I am going to use some hi-temp paint and paint them. Powder coating sounds great but budget wise, I dont know.
I will update with pix soon!
