Flasher relay
Kenjan
Ok guys
Can s1 give me the oem
Relay/flasher #
For turn signals
I have led bulbs -for free to install in the front
And rear turn signal also
I have hyper flash now with reg bulbs
168 I believe they are
If I put LEDs in they don't flash
So I need to upgrade I believe to led flasher relay
I know where the relay but mine has no #
Or if s1 knows of one Post up pls
I have the res I could use but...
I rather do the relay
Source a Tridon EP35 Flasher relay for the rapid hyper turn signal issue. I purchased mine through a local auto supply store..... Autozone. I've also seen them on Amazon.
Hope this helps........ 8sm
Anyone have the carquest #
And what's the difference between
Ep-35 vs Ep-36??
http://www.tridon.com.au/Products/Product.aspx?SG=8&S=35&G=478&P=2000
More to the point, the EP35 is listed for our 4Runners and the EP36 is not.
peacefulpiranha
