Floor mats
Mack2182
Does the Trail edition have different floor mats than say the SR5? Just bought a 2013 and I feel as though the dealership pulled a set from an SR5 because they couldn't find mine. Thanks
I believe SR5, LE, and TE mats are all the same fit, however, 2010, 2011, 2012 4R's have different fasteners to keep them in place vs. the 2013's.
I'd make sure the mats they give you are for 2013, I'd suspect that's the problem.
agreed. My 2013 SR5 came with the standard carpet mats and the all weather mats. The carpet mats were perfect but the all weathers weren't made to use the rotating clips that are found in the 2013. only one of the four holes in the front mats match the clips and thats the drivers side left hole. other three don't line up at all.
Yup the mats should be the same across all editions but, as [MENTION=100314]gringo[/MENTION] says, I believe the 13+ fasteners are a bit different than the 10-12's. If you are looking at the Toyota all weather mats I'd suggest you look at WeatherTech instead.
I'd second that. I've had the Toyota rubber mats for about 2 years and 20k miles. They are worn smooth in spots, curled up at the corner, and tearing at the mounting hook. I like to point it out when I'm in for service and tech checks off that he inspected the floor mats.
delislerebecca
