fluid flushes necessary?
Interesting thread with a lot of good ideas/info.
When dealers use the word "Flush" I personally wonder what they actually mean. Are they using a machine that vacuums out the oil fluid and pumps new fluid in under pressure? Does the machine vacuum out the oil fluid, pump a cleaning solvent (under pressure) through the system then pump the replacement fluid in? Or is the word "Flush" simply a fancy sales/marketing term for draining & refilling the fluid that is used in order to justify the cost being charged for the service? Depending on what exactly is being done when a fluid is "Flushed" I could see some cause for concern. If it is a simple drain/fill then I would not be as concerned with certain fluids.
Maybe BWInc can comment on this given his experience where he works?
Do you have machines that actually "Flush" (under pressure) that are used to change the fluids being discussed here?
Obviously, machines/methods can/will vary from dealership to dealership.
leolediola
