Fog Light Anytime Mod Comparison
Apples and grapes. Different factory wiring means the 4th gen probably won't work on 5th gen and from what I see, might harm the ECU
5th Gens have multiple light relays housed and sealed in plastic boxes and they call them ECU's rather then separate relays like 4th Gens.
Antman's way is quite ingenious and well thought out and the way to go if using the factory switch!Either that or wire them to a separate switch and relay as I used to have mine.
Thanks Gary! That means a lot coming from such an accomplished mechanic/modder as yourself.
Maybe one day I can buy you a beer?! :cheers:
I have been reading through the Fog Light Anytime threads and want to see what the hive-mind thinks about the similarities and differences between these two:
1) Antman's mod on his 5th gen
http://www.toyota-4runner.org/5th-gen-t4rs/92013-antmans-thread-2.html#post811096
vs.
2) This mod to a 4th gen
Toyota 4Runner Independent use of Fog Light Mod
My thoughts are that the second version seems cleaner.....
ohhhhhhh NOooooo you di'int!!!!
ohnoyoudidnt.gif~original
matisgugle
