Fog Light Bulb Confusion
SoCal4Run
Ok, so I orders some new bulbs for my foglights. Have a 2014 SR5 Premium. Ordered a pair of H16 bulbs per the manual. However, what i received has a different base than what is on the car? Am I missing something? Am I supposed to switch the base over? Are these H11 or something else? It says H16 on the stock bulb, but why does it have a 90 degree connector rather than the straight on plug like the H16's I got in the mail. Please help.
Does the stock bulb unplug from the 90 degree base. And I'm supposed to remove the bottom plastic from my new bulbs to install into that base? I'm so confused. Thought it would be just plug and play.
I think that bulb is designed to work with 5202 /5201 / h16 and others. There is nothing that can be removed from the OEM bulb and the harness should just plug on to the back of that bulb even though it doesn't have the 90 on it. Depending on manufacture it may not matter which way you plug the bulb in but if it doesn't work try flipping the plug around
Thanks for the help. I think the plug will still work, but my concern is mounting it into the housing. Doesn't seem to have the same mounting setup.
Ok, so here is the true comparison. Stock bulb on left with 90 degree base. Beginning to wonder if it's really H16 or something else. There is no way the new bulb will work in my car.
20140214_220257.jpg~original
20140214_220249.jpg~original
It is a true H16 as printed on the bulb and in the manual
Edit: I have not actually seen the 2014 fog lights, but I can't imagine they would have a typo in the manual as well as have h16 printed on a h11 bulb.
Edit again: From some searching it looks that a h16 and h11 are the same size / form factor. Difference being that h16 are only 19w vs 55
Expand your search beyond T4R.org.
A quick Google of "H11 vs. H16 bulb" found this.
Well let me call you search God. You're right, never thought of trying Google. Just didn't see that one. And am I to assume it's the same for 4 runners then as Subarus? Just thought a forum was a place to ask and get information. I don't understand why everyone harps on people about searching.
I may be late to the party, but I was reading on a Subaru forum that you should specifically look for "H16 OSRAM". I just did the same and found quite a few that look exactly like what you pulled out of your '14. I also read they are the same for H11's except for the bulb (not base) size and wattage. I'm going to buy a cheap H11 and see how it does to see if the circuit will handle the extra power. Personally, I'm looking to add some 4300K Morimotos and want a yellow fog to contrast the HID low beams. These are kinda pricy ($130 / pair), but I like the color. LED FOG LIGHT BULB They're also not the brightest (only 600 lm each), but with the 4300K HIDs I plan to get, it shouldn't matter. I'm going more for the look here over function. If I want some serious fogs, I'll add a pair.
I had 3000K HIDs in the fogs on my old '06, but I didn't like where I had to mount the ballasts. With the LED bulbs there are no ballasts.
The H11 base is slightly different than the H16, but H11s fit easily with slight modification to the fog light assembly.
This ^
I bought some Hella H11 yellows for the fogs and just cut a tiny bit off 2 of the three tabs on the base if the bulb. Fits perfectly and looks great.
Anyone know, for sure, whether the H11 bulb @55 watts is too much for the stock fog lens, housing and wiring?
TerryNap61
