Fog light connector name / type?
yotadawgjr
Anyone know what the OEM fog light connector type is?
I would like to get a mating connector and make an adapter to connect from the truck's stock wiring to my Baja Designs SAE fogs. I'd prefer not to cut off a perfectly good working connector in case I decide to go with OEM fog lights in the future
In my stupid opinion; If you are comfortable enough with cutting/soldering/crimping/repinning to add an oem style connector to your Baja Designs fogs, you will be more than capable enough of returning them to stock, if you should wish.
If you already have the Baja Designs fogs I can't imagine why you would want to go back to OEM.
I used the OEM fog power circuit as the trigger wire for the relay that turns on my 25,000 lumen Amazon fogs. You could just interrupt the wire or wiretap it before the connector to do this.
The BD fogs came with mating connectors. For sure I could just cut the oem connector off and use them but it just doesn't sit well with me.
Also if I decide to change to something other then the BD, I could simply hack up my adapter instead of cutting and shortening the stock wiring again (and in the comfort of my home :) vs under the truck)
You are right, there's a high probability I'll never install OEM fogs, but maybe the next owner would? I think they would be disappointed to find a non standard connector there.
charlesz
