For all that have ATX Mojave wheels
RJS-T4R
These ATX Mojave wheels are the perfect match for trail edition. But I am not sure about the teflon finish.
I need your opinion on how the teflon finish is holding on, is it easily scratched?
Thanks in advance.
I believe there are indeed a few people on here who have those rims, but I'm not sure they've had them very long. Probably not long enough to really give you a good long-term review. You probably want to talk to someone who's had them at least a year...
Maybe search around on the other forums, as well? It's the same wheel finish no matter what vehicle you put them on. :)
I've had my Mojaves on since March with 14000+ miles on them already. They've been offroad from the Appalachians across to Utah and still look like new with just a couple of minor rock scars obtained at Moab. My tires have alot of sidewall which helps protect them too.
At first I thought the Teflon paint job was a coating of crap as it was'nt powder coated and not even painted fully on the back side. I even was going to have them powder coated flat black when I first got them. But they have held up better then expected and they are so easy to keep clean.
I bought mine here in this size.... American Racing ATX Mojave Teflon Wheels 17x8 Boltpattern 6x5.5 (6x139.7) Offset 0 Hub Bore 108 Partnumber AX39817883
Call if your going to order and they'll throw in the black conical lug nuts for free if you ask!Transaction was smooth for me and they were at my door 4 days later.
since these wheels are 17x8, oem sr5 and trail are 17x7/7.5. can I put these wheels on my limited with 265/70 17 tires without any lift?
please give some advise :lookout:
Yes, You should be fine considering the back spacing is correct. And FYI the SR5 wheels are only 7" wide. :sobbing:
Yes they will fit you might have some rubbing tonkat has these wheels with toyo m/ts in 265/70/17 she has no rubbing. I have my trail leveled with the same rims and nitto terra grapplers and I rub at full lock with wheels cranked full passenger when backing up
Thanks for the reply
since you guys have the trail edition, is there anybody own a sr5/limited running these 17X8 without any problem? of course no lift......
You should be fine can't see why they wouldn't fit. If and when you do buy them any good tire shop should let you do a test fit up front and crank it side to side just to be sure they fit.
I don't have these wheels but I do have an LE and was running a set of 20x9", 5.7" bs, +18mm offset wheels with 275/55 tires and no lift. No fitment or rubbing issues. At 17x8", 4.5"bs, and 0mm offset you shouldn't have any problems. Like hamilton said above, a good shop will let you test fit the wheel, i was able to. Good luck.
:cheers:
Jesse1
