Front End Replacements (tie rods, ball joints etc)
jay4runner
My 1990 4wd, 4cyl 4Runner has over 350k km. Still runs great. Was advised the other day during an oil change that the RF inner/outer tie rods, RF idler arm, LF upper ball joint and all shocks need replacing.
I have done some reading on the internet (including this site) and have a bit of a plan, however, would appreciate some further advice.
For the tie rods I found a toyota part that seems to be the complete inner/outer tie rod assembly (45460-39505). Would it be better to purchase this entire assembly? Also, if I replace on the right side is it advisable to also replace on the left (so that both sides are updated)? Is this a fairly easy replacement - can one with basic mechanical skills/tools likely complete?
For the idler arm there is quite a range of prices. My Toyota dealer quoted me $445 for the part. It appears that I can get the genuine toyota part online (Toyotapartszone) for $200. Then I see that you can get other brand ones such as the Sankai for $128 (Partsgeek) which is evidently the company that makes the oem? I have also seen some comment that perhaps one can just replace the bushings on the original idler arm - does this make it as good as new? And with the idler arm repair are you best to do both sides? Is this a fairly easy replacement - can one with basic mechanical skills/tools likely complete?
For the upper ball joint should I stick with original toyota parts? Again, am I best to do both sides? Is this a fairly easy replacement - can one with basic mechanical skills/tools likely complete?
Any recommendations on particular shocks?
Perhaps most importantly are there any other key parts/components that I should probably be looking to replace at the same time?
Thank you for your comments/advice.
You can rebuild the idler arm, there are several how-to's if you search the web.
As for brands, I try to avoid brands I've never heard of and some of the big chain parts store bargain brands. There's a couple of tools that make separating the ball joints easier (commonly referred to as a pickle fork), HF carries them at a reasonable price.
tobasko556
