FS 2002 4RUNNER 4wd BUILT...325k $10,500
xcmountain80
I'm putting my truck on the market, pictures to follow.
Located in Jupiter, and Port Charlotte FL.
Asking $10,500 obo.
SUSPENSION & DRIVETRAIN
• 1st gen Tundra 4wd coils
• Sonoran Steel Bilstein 5100 adjustable strut
• ToyTec 0.5” Top Out Spacer
• ToyTec Superflex rear springs
• Bilstein 5100 RearShocks
• Stainless Steel Extended Brake Lines front
• 1" 4Crawler Body Lift
• Yukon 4.88 Gears F&R with crush sleeve eliminator
• Sonoran Steel Extanded Bump Stops
• True Trac Limited Slip Rear
• Aussi Locker Front
• Tacoma Aisin Manual Hub Conversion
• Rear Lower Link Sonoran Steel
• Adjusted Panhard Bar Sonoran Steel
• Replaced double cardan joint with Spicer serviceable joints.
• Tundra 231mm Brake upgrade (caliper & rotor)
• Kartek Offroad/ Sonoran Steel Limit straps Front
WHEELS & TIRES
• 295/75/16 Nitto Terra Grappler (33.27x 11.73) with 22k on them. I get between 55-60k miles out if these tires and this is my 3rd set on this vehicle.
• Lexus LX450 16x8 Painted in Infiniti Slate blue
• Matching Spare Unpainted in Factory condition
OFF-ROAD & ARMOR
• ARB Front Bumper painted to match, TIR6 styles turn indicators
• MasterPull XD Line (Synthetic Rope)
• TMax 9,000Lb Winch with remote control
• Custom square tube sliders with 5 degree kickout coated with Hot Spray coating
• Extended Rear Differential Breather
• BudBuilt Front and Belly Skid Plates
LIGHTING & ELECTRICAL
• Headlight Services Upgraded Headlamp Harness
• Blue Sea 5026 - 12 Circuit Fuse Box in cab
• Ground and Power Distribution blocks under hood
• Ruff Stuff Battery cage
EXTERIOR
• Painted to match rill and Bumpers (bumpers have been kissed on both sides from my trailer.
• Andre Diaz Devil Horns
• Yakima Control Towers and crossbars
• Hitch
• 7-way plug
• 4-way Flat plug
INTERIOR
• GREAT Condition Leather Power Seats (Recently Installed)
• Husky Floor liners
• Alligator Vinyl Center console cover
• New Headliner
ENGINE & PERFORMANCE
• Deckplate Mod
• B&M 70268 Transmission Cooler
• Doug Thorley Headers
• Magnaflow Hi-Flow Muffler
• Magnaflow Hi-Flow Cat (Had 2 now just 1)
• K&N Air Filter
• URD O2Simulator
• Superlift Speed Calibrator
Fluids
• Royal Purple & Filter every 15k
• Oil Filter: Purolator Pure One
• Transfer Case: Royal Purple 75W-90
• Front Differential: Royal Purple 75W-90
• Rear Differential: Lucas Gear Oil 75W-90
Condition
• The vehicle has 325k miles on it, I purchased it with 69k in October of 2005
• No accidents more severe than a bump or bruise
• Paint is good with scratches typical of a 11 year old vehicle
• Motor 5VZFE is 8,000 miles new. The original motor was removed at 225K and replaced with a refreshed 5VZFE which lasted 90K. The current motor came from JIS Engine rebuilders of Texas.
B4A1B54C-0F76-46F2-BB93-D39077753DE9-8421-00000B689475E208_zps374191d8.jpg~original
