FS: 5th GEN 4Runner - gray, $32.5k VA Beach, VA
swimmerdude1127
For sale is a purpose-built Toyota 4Runner with serious offroad upgrades you're able to do this series of vehicle. It's a 2013 Toyota 4Runner SR5 with very low miles (37k) in magnetic gray metallic with far more upgrades than come standard on the stock Trail Edition or TRD Pro. The reason I am selling it is because I am looking for a pickup truck for hauling, and I no longer have the time to enjoy this vehicle as it's built. This truck has over $25,000 in upgrades and modifications alone. Please read the ad in its entirety if you're interested. Serious inquiries for potential buyers only. I am not parting it out, but if you want to negotiate price then I can start taking things off. Price drop to $32,500. No trades. If you want to contact me directly, feel free to text/call at seven 0 4, six 4 nine/ 7 eight 6 one
Modifications broken down by amount:
5k+ in lighting
5k in armor
6k in suspension
2.5k in wheels and tires
4.5k gearing, air compressor, diff lockers
4k in Accessories - roof rack, winch, etc
Lighting and electronics. All LED light bars are Rigid Industries. Over $5,000 in lighting upgrades.
40" rigid spot/flood hybrid LED bar
2x 6" rigid industries driving pattern LED bar
10" rigid industries spot pattern LED bar
20" rigid industries amber flood pattern LED bar
30" rigid industries spot/flood hybrid LED bar
Rear-facing lighting
4x rigid industries sr2 pattern LED bars
2x rigid industries in bumper, diffused beam pattern
Black Flame custom HID projector retrofit - $2000 value
-Quad HID projector retrofit (FX-R & MH1 projectors in each housing) in OEM style headlight 4Runner housing
-custom amber halos behind Apollo shrouds (inner projector) and Gatling shrouds (outer projector)
Under-body LED rock lights - $150 value
Under-hood fuse panel for 8 circuits, wired with single main 100A fuse
Cab-mounted switch bracket and OTRATTW switches
Roof rack system - $2000
Gobi roof rack with forward mounted tool box
Roof rack ladder mounted on rear hatch
Rotopax mount and 5gal flat pack fuel carrier included
Hi-lift jack roof rack mount on driver side
Armor - $5000 in armor
Shrockworks full armor set - $3500 value before the winch
Shrockworks front bumper with Warn 9.5XP and MasterPull 12k synthetic line
Shrockworks sliders
Shrockworks full 5 piece skid plate set
CBI Offroad Fab rear bumper with tire carrier, gas-can swing out, gas can carrier, and hi-lift mount
-full size spare with SCS-6 wheel and 285/70/17 Goodyear MT/R Kevlar. Dual Scepter 5gal Jerry cans (one fuel and one water)
Wheels and tires- $2500 value
Stealth custom series SCS-6 wheels black (with fifth spare)
Goodyear MT/R kevlar 305/70/17 (34's)
Gearing, diffs, air - $4500 value
Re-geared 4.56 gears for better 4WD low-end torque; work done by East Coast Gear Supply (ECGS)
Front and rear ARB air lockers
Under-hood ARB dual air compressor (largest they make) with under-hood air chuck and custom heavy duty fabricated mounts for compressor
Suspension - $6000 value
Icon custom stage suspension components (front and rear) with Total Chaos Lower control arms (front) and MetalTech overbuilt lower control arms (rear)
Total chaos lower control arms with uniball joint
Icon tubular upper control arms with uniball joint
Icon coilovers with CDC valving (allows you to adjust rigidity of suspension 1-10) and 700lb rated springs (due to weight of front bumper and skid plates) and PVD corrosion-resistant coating
Icon rear shocks with CDC valving (allows you to adjust rigidity of suspension 1-10) and PVD corrosion resistant coating
MetalTech extended travel rear springs, heavy rating (due to weight of rear bumper)
Magnaflow stainless performance muffler . Exhaust dumped just after rear axle
Fire extinguisher and bracket custom installed inside cargo area
The bad
Winch on the fritz and possibly needs new motor
Right rear quarter panel has light scrape from where I rubbed against a tree.
Spot on rear armor bumper has some rust developing and will need to be painted at some point.
So much want for this. May I ask how you have so little miles with this vehicle, and how many miles all the extras have on them?
I'm in the military and am often away for work, which is why it has low miles. Started with mods at about 8k and haven't done much additional since ~20k miles.
jisoo200
