FS: 99 4Runner SR5 4x4 5-speed VA
Killswitch
Price drop for quick sale. $10250.00
Specs:
1999 Toyota 4Runner, SR5, 4x4, 5-speed manual, 173k, Stellar Blue, factory power moonroof, AC, power windows, power door locks, Alpine head unit with Bluetooth and USB, Weathertech floor mats etc.
Replaced in the last 4 months:
2001 frame (media blasted, prepped and painted with 2 coats of POR15)
Body mounts
Transmission mount
Front sway bar bushings and end links
Rear sway bar bushings and end links
Front and rear control arm bushings
Front upper and lower ball joints
Inner and outer tie rod ends
Steering rack
Tundra big brake upgrade (231mm) inc calipers, rotors and pads
Goodridge stainless front brake hoses
Cleaned and adjusted rear brakes (approx 60% remaining)
Replace rear u-joint and balanced driveshaft
Bilstein 5100 front and rear shocks
Toyota "tall" Highlander Edition springs
Toyota black 17" TRD wheels
BF Goodrich KO2 265/70/17 tires
Upper and lower intake manifold gaskets
Valve cover gaskets
Differential breather
Rear axle seals
Brake hard lines
Fuel hard lines
PCV valve
Air filter
Fuel filter
Spark plugs
Spark plug wires
Exhaust gaskets
Rear lift gate window regulator, both tracks, switch and all hardware
All 3 accessory drive belts
Power steering flush
Brake fluid flush
Clutch fluid flush
AC evac and recharge
Front and rear synthetic differential service
Synthetic transfer case service
All underbody grease fittings lubricated
Satoshi grill from SRQ fabrication
Left and right headlight bulbs
All tail light bulbs
*synthetic oil and filter change and first tire rotation completed last Friday
** all parts replaced are OEM Toyota unless noted.
The previous owner replaced the clutch, timing belt, water pump and cam seals approximately 30k ago.
Reason for sale: This truck hasn't gone off road and likely won't in the future. I'm focusing on restoring an old BMW and would like the runner to go to someone who will actually use it for something other than just a daily driver. The selling price reflects what I have invested. I'm looking to break even, not make any money. This truck literally needs nothing. I'm located in Norfolk VA and am willing to drive up to 300 miles for delivery. As far as reliability goes, in the last 6 weeks I've driven back and forth from Virginia to Boston (600 miles each way) with zero issues. Truck averaged 330 miles per tank of gas. I have a stack of receipts and a clean title in hand.
$11,000
Good luck with this, it looks like an awesome truck and your effort shows. I'd buy this if I had 10k.
alexaturner
