FS in NH: 1996 4Runner 5spd, elocker, many extras. NO RUST
clemson4r
****SOLD****
Hi all,
I’m putting my 1996 Toyota 4Runner 5 speed SR5 up for sale. I purchased this from the original owner and the truck spent its entire life in SC and NC, as a result, there is NO rust, the body and frame are in amazing shape. I moved to NH with this truck almost 2 years ago and it has been garaged the entire time I’ve had it, along with frame coating applied every season (just applied a fresh coating of Noxudul). I’m selling because I’m moving and am keeping my BMW. I've taken this onto trails a total of ~4 times in the +3 years I've owned it.
I have done quite a bit of work to this truck, mostly maintenance and all maintenance parts were replaced with Toyota OEM parts. Oil changed at 5000 miles or before with Mobil 1 and all drivetrain oils are synthetic 75w-90. The truck has 208,xxx miles on it, and most all of those are highway miles as I drive a lot. Below is a list of parts and features of this truck:
Maintenance:
- OEM timing belt and water pump (172,428)
- OEM accessory belts (172,428)
- OEM upper and lower ball joints (172,428)
- Tie rod ends, front and rear swaybar endlinks (172,428)
- CV axle rebuild with OEM kits – both sides (177,000)
- Starter rebuild with OEM contacts and magnetic plunger (177,000)
- OEM valve cover gaskets and intake manifold gaskets (177,000)
- OEM Aisin clutch kit (with pilot and throwout bearing), flywheel machined, OEM rear main seal, t-case seals, Marlin shifter bushings (181,694)
- OEM steering rack guide (181,694)
- OEM front lower control arms (201,200)
- Windshield replacement (208,000)
- OEM spark plugs (208,000)
- OEM tailgate window regulator replacement
Suspension/upgrades:
- Toytec springs/Bilstein 5100 front
- OME 891 springs/Bilstein 5100 rear
- Tundra brake upgrade with OEM pads and rotors
- Sonoran Steel adjustable panhard bar
- OEM rear e-locker axle, 4.30 gears, wired using OEM computer and dash light
- Toytec diff drop
- 285/75/16 Goodyear Wrangler Duratracs (On Tacoma 16inch wheels now, not TRD team wheels)
- Savage Offroad full skidplate set
- Trail Gear sliders
Interior:
- USA Spec iPod integration
- Polk Audio DB 6501 front component speakers, DX 6501 rear 5.25” speakers
- OTRATTW light switches and switch bezel
- 99 4Runner center console
- 99 4Runner steering wheel retrofit
- Weathertech floormats front and rear
Exterior:
- Roof, hood, and tailgate repainted due to clearcoat peeling
- Kurt hitch
- Ditch LED lights with CBI brackets
- Flush mount LED reverse lights
- 30” LED bar with Slag Offroad mount
- 99 4Runner headlights
I’m sure I’m forgetting some other bits, but that is the main list. As stated, the TRD team wheels will be included at my asking price, but otherwise I will put on a set of split-spokes with the tires. Please let me know if you have any questions at all. This has been a fantastic vehicle and I’m hoping someone here can find a use for it.
Max
Me neither...Pictures are good...sounds like a really nice well taken care of 4runner. Looking forward to seeing what it looks like.
Max,
Might just be my computer, but your pictures didn't post.
GLWS!
Sorry about that. Uploaded some to the original post and the rest here
Max
I started this a bit high, so I've put the price at $9,000 instead. I've had some interest but wanted to lower the price a bit.
Let me know if there are any other questions
Max
Also selling my trailer I built with 33" General Grabber tires. Sits perfectly level with the truck and rides very well down the road due to the tire weight. Has a proper serial/registration number stamped onto the frame. Selling this for $500 or can do a package deal with the truck
Max
