FS: Used OME 883s, Bilstein Adj 5100s, and 1/4 Top Plates
JWaldz
Moderator
All Items Sold
Lift was installed in December of 2009 and top plates were added on December of 2011. All from ToyTecLifts.
The lift has served me well, but I have moved on to coilovers. The Bilsteins will need some attention if not replaced all together. The top stud on one of them is stripped out. If you take the nut off, it will not go back on. I don't know if this is a repairable thing, but I believe you can contact bilstein and get a new top stud pressed in. Again, I'm not sure. CHECK before you buy. Also, this same shock also squeaks significantly. A good cleaning might take care of this problem. The other shock is in better shape, could use a cleaning as well. They do not bottom out and still work as they should.
The coils are in used condition but still serve their purpose. They are not heavily worn but do show signs of usage. There is a little surface rust here and there, but isn't bad. I think it's just from weather getting to the spots that the coating was rubbed off using the spring compressor. These are medium duty coils so they do call for additional weight up front. I was able to achieve close to 3" of lift at the middle setting with aftermarket skid and bumper. It was a tolerable ride, but not for comfort.
Like I said, this setup has definitely been used and shows it's 3 years of age. I honestly don't know how many miles I have on it but I can guesstimate around 30K.
That being said, on to prices. I will not separate the coils/shocks, so please don't ask.
OME/Bilstein Lift: $175 OBO + shipping.
1/4" Top Plates $25 shipped. SOLD
I will get pics VERY soon. Located in Little Rock, AR. Paypal only.
-J
References:
OME Coils - Toytec
Bilstein Adj. 5100 - Toytec
1/4" Top Plates - Toytec
2DF9E35E-6CBD-46CB-9493-E089AD1676AE-19260-000005F7B9327C9B.jpg~original
You can see on the shock on the left that the nut sits higher on the top stud. This is bc of the stud being stripped out and the nut won't go any further. Loctite has been applied and it's been this way for a while.
BA3F5D27-9A9F-42DB-8444-F807F694AA9A-19260-000005F7C2B1360A.jpg~original
pugowks
