FS: Very Clean! 3rd GEN 1999 T4R (Manual Trans.) Desert Dune $13,500 PCB FL.
frankc
1999 Toyota 4runner, Manual transmission 5 speed Desert Dune Metallic - 206,700 miles
Very nice condition and meticulously maintained - garage kept - 2 owner car. Purchased from Calif. in 2015 and shipped it to Fl. Driven 1-2x per week. Not a daily driver. Shiny, dent / ding free paint and bumpers, clean interior - passenger seat and 2nd row leather looks great, and all carpet looks brand new. Driver seat has normal wear and normal Toyota leather deterioration. Clean engine compartment. Not used off road.
Fluid Filmed the underside frame and applied Eastwood internal frame coating inside the frame. There was no rust on it when I bought it, and it remains rust free - everywhere.
Upgrades or maintenance performed: (I have all receipts for the below items and much more)
-Sherpa aluminum roof rack (Matterhorn) ($1400)
-Five (5) new 17 inch wheels and Michelin tires 265 70 17 (Less than 4,000 miles (Yes, a new matching wheel and tire for spare, which has been rotated in during tire rotations).
-TRD (Borla) Cat-Back exhaust - Stainless.
-Airaid cold air intake - dry filter (I have original housing bits)
-Timing belt changed only 18,000 miles ago (100,000 mile interval)
-New OEM radiator, thermostat, hoses and clamps
-New OEM CV axles
-New OEM inner and outer tie rods
-New OEM lower ball joints
-New OEM alternator and wiring upgrade
-New OEM rear cargo door latch
-New OEM vacuum hoses
-O2 Sensors
-Valve cover gaskets - OEM
-Tundra big brake upgrade (Power Stop calipers / OEM rotors, stainless brake lines)
-Bilstein 5100 shocks, front (adjustable) and rear
-Old Man Emu 906 rear coils
- Approx 1 inch lift over stock, 1999 4runners already had taller coils from the factory so
it looks a little taller.
-Satoshi grill with raptor lights (not yet wired)
-Dash mounted Modular accessory mount - Teq Off Road
-RAD rubber wheel well eng. Splash guards.
-Battery - approx. 1 year old - painted battery area;
-Tinted windows
-Weather tech floor liners front and back
-Stryker front hood struts
-Susquehanna upgraded headlight harness
-Recently painted skid plates, hitch painted, front bumper removed and inside painted
-Scan Guage II ashtray mount (Still have stock ashtray)
….and more
Maintenance meticulously performed - Amsoil, Mobil 1, Redline MT fluids, Frt - Rr diffs, OEM spark plugs, wires, etc. All new OEM vacuum hoses on engine. Dozens of receipts.
All bolts torqued as per manufacturer specs, using loctite or anti-seize as applicable
Parts included but not installed:
- $400 - Bushwacker Extend-A-Fender Extended Front & Rear Fender Flares | 4-Piece Set, Black, Smooth Finish | 31913-11
- $300 - 3.4L/V6 Timing Belt - Water Pump 14 piece kit
- Everything needed to service your timing belt
- Desert Does It Seat Jackers. Raises the front of the front seat up 1 inch for leg support.
- Energy Suspension steering rack - pinion bushing set (urethane bushings)
- Energy suspension Sway bar bushing kit
- Custom mesh grill for 99-02 4runner and toyota grill emblem
- Nice car cover
- I also have both original floor boards.
Also Included:
- OEM shop service manuals $170 (Three - 2 inch thick manuals)
- Front dash carpet mat (2)
I treated this 4runner as a ‘forever car’ (because the internet said it will never die), but it’s time to make room for other projects. If you want more info, pictures or anything, let me know.
I doubt there is a cleaner version out there.
MikeV5280
