fuel injector replacement
Which spec injectors to use on a 3.4L '99 5VZ-FE?
I actually have two 4Runners that need this repair, a '99 and a '98, with 220k and 275k miles respectively. Same engine (5VZ-FE, 3.4L). '98 has a dead #2 injector and the '99 has an overall power loss, not terrible but calling for injector replacement soon. When I do these jobs I will replace all 6 injectors on both cars.
The Racers Edge has 4 choices of "Injector Dynamics" brand and the prices vary wildly. The CC/Min ratings and the Maximum Differential Fuel Pressure numbers differ also.
Toyota 4Runner 1998
Choice 1 $780:
SKU: ID1050.60.14.D.6
This is a set of 6 Injector Dynamics ID1050 fuel injectors. Top-feed 14mm applications for 1996-2002 Toyota 4Runner / 5VZ-FE.
Nominal Flow Rate – 1065cc/min @ 43.5 psi (3 Bar)
Maximum Differential Fuel Pressure – 145.0 psi (10.0 Bar)
Fuel Compatibility – Compatible With All Known Fuels
Electrical Connector – EV6 / USCAR *No Adaptor, Orange lower o-ring*
Choice 2 $1350:
SKU: ID1300.60.14.D.6
This is a set of 6 Injector Dynamics ID1300 fuel injectors. Top-feed 14mm applications for 1996-2002 Toyota 4Runner / 5VZ-FE.
Nominal Flow Rate – 1340cc/min @ 43.5 psi (3 Bar)
Maximum Differential Fuel Pressure – 87 psi (6 Bar)
Electrical Connector – US EV-6 *Adaptor top, Denso lowers*
Choice 3 $1740:
SKU: ID1700.60.14.D.6
This is a set of 6 Injector Dynamics ID1700 fuel injectors. Top-feed 14mm applications for 1996-2002 Toyota 4Runner / 5VZ-FE.
Nominal Flow Rate – 1725cc/min @ 43.5 psi (3 Bar)
Maximum Differential Fuel Pressure – 101.5 psi (7 Bar)
Choice 4 $1440:
SKU: ID2000.60.14.D.6
This is a set of 6 Injector Dynamics ID2000 fuel injectors. Top-feed 14mm applications for 1996-2002 Toyota 4Runner / 5VZ-FE.
Nominal Flow Rate – 2225cc/min @ 43.5 psi (3 Bar)
Maximum Differential Fuel Pressure – 130.5 psi (9 Bar)
Then I found these two choices (thanks to this forum) from FiveO Motorsports, reman Densos:
Denso Fuel Injectors, 1999-2002 Toyota 4Runner, 2000-2004 Tundra, 1999-2004 Tacoma 3.4L
It looks like the FiveO selections are the same part, they use the same pic for both, but maybe the PSI specs are different?
I know that having the same specs on all 6 injectors is the desired setup. I was going to get the FiveO parts, but when I saw the different ratings and extreme price differences Racers Edge offers it went above my pay grade, so thanks in advance for any insight into this matter. I have no experience with fuel injector specs, I just know how to replace them, LOL.
Any thoughts? How do the above ratings correlate to things like engine power, performance, and fuel consumption? Will the higher CC/Min injectors consume more fuel overall, or will they deliver a higher fuel flow only upon rapid acceleration? Then I started to wonder whether the lower rated CC/Min parts would provide a leaner mixture and a hotter burn. Or is that even the way it works???? And what are the "Bar" ratings? Please help! LMAO :cheers:
Lastly (and thank you for your patience!), does anyone know the factory spcs Toyota used during the production runs, or did that vary? I looked at a dozen Toyota parts suppliers and while they have different injectors listed for the same application, none of them have the specs listed like Racers Edge does.
:yo:
I think you should take a look at the video I posted and read the video description. Call the company I linked and they will get you a set of injectors for much much more of a affordable price than the crazy options you posted.
I replaced injectors 1 3 and 5 last week. I had been dreading this job for a long time but it really wasn't all that bad. I got the upper plenum off, cleaned it, and replaced the gasket, but I was feeling lazy and didn't remove the lower to get access to injectors 2 4 and 6. It's probably possible to replace 1 3 5 without evev removing the upper plenum - you definitely don't need to remove the fuel rod, I just kind of twisted it up and rocked the injectors out. Took maybe 4 hours start to finish with a lot of breaks and a detour to remove and replace a stripped screw on my maf sensor. Could definitely do the job in about two hours if I did it again.
I replaced all mine when injector 2 took a dump on me and ohmed st over 23 ohms at the internal coil.
I used OEM rebuilds from MotorWest and replaced all 6 that were flow matched. I replaced valve cover gaskets while in there and painted valve covers and degreased and pressure washed the manifolds and replaced vacuum lines.
Tim’s video made it a breeze.
FWIW I did the even injectors on my 99 v6 5 years ago w/ Beck Arnley's from Advance Auto. 5 years, and 60K miles later I have had no issues. Looking back I wish I had done them all, but it wasn't in the budget at the time. I needed to get the car up and running ASAP and those were the only ones in stock (tried dealership as well). Using a variety of 20% off online purchase coupons I got them at a decent price.
I still don't understand why the coupons are only good online. Can't tell you the number of times I've gone in for a part, had them pull it from the back, then gone online to purchase and use coupon, so they could hand it over to me.
This spring I had an issue with #6 injector on my 99 (228K miles). Ran fine most of the time, but if the engine got really warmed up, it would start intermittently missing, progressing to a fulltime miss and a #6 misfire code. When the engine cooled back down, it would run on all6 again with no signs of trouble.
So I got it nice and hot and missing, and tried to troubleshoot it by moving wires and coil packs around. And the miss stayed firm on #6. It was clearly not a mechanical (compression) issue because of the on-off way it operated. So... injector.
My mistake? Getting on eBay and buying a set of 'BRAND NEW GENUINE OEM 100% GENUINE INJECTORS' for about $250. Yes, there's absolutely no way you're going to get brand new 'real' OEM injectors for $250. Dumb me. Got them in, they were in some shady foil packets (I forget the wording on them, but it didn't inspire confidence. The injectors themselves? Really good fakes. I looked at the original injecors and those side by side up close, and I really couldn't see anything wrong with them. Other than a skinny looking set of red o-rings. So I put them in.
And...it was hard to start. Like 10 seconds of cranking. Hot and cold. Maybe a little better in a 'warm' start. Clearly, one or more of them was leaking down while sitting. Told the seller this, they said they needed to 'break in' and to drive it for 50 - 100 miles and see if it improved. I did that, if anything it got worse. Ah well, I took them out and returned them, at least the seller gave me a 100% refund (in exchange for not leaving feedback).
And I went to a junkyard and got a set of used injectors from a wrecked '00 4Runner. When I pulled them off the fuel rail, fuel sprayed out under pressure. Lol, no leaks on this set - they'd been holding pressure for at least a month or more. Stuck them in, it runs perfectly, cost only about $50 for the set. I figure a junkyard set with 200K on them are probably a better idea than a 'new' set of eBay knockoffs.
I had a cylinder 3 misfire a couple weeks ago. Replaced the coil, it ran great for 2 days. Now it’s running terrible, hesitating when you press gas pedal when you first take off. Surging in park.
So we replaced the spark plugs, cables and coil 3 again. Still runs terrible. Can it be an injector?
Hey have you tried cleaning the MAF sensor, as my 1999 was runing pretty bad, and had no power. so i cleaned the sensor and it is way better. also look at your pcv valve as that is the easiest fix.
tssawlson538
