Fuel Injectors O-Ring grease help.
aa010175
I purchased MotorWest rebuilt Fuel Injectors and need grease ideas for the O-Rings. The Toyota parts man told me to use white Lithium grease.
If you ordered through motor west they should have included a small plastic sleeve of "superlube"
Look through the contents of the package thoroughly.
+1 for motor oil, but I've also heard of people using straight gasoline, too. Not sure why?
x3 on motor oil..I've rebuilt/swapped numerous injectors in my day(not for Toyotas) and that's all I ever use. Only need a drop.
After a few ripped o rings on my 3zve, the napa guy reccomended this stuff and it is now my go to. It works so well!
IWrvgeZC_KwpQ9EpQzqIpcc4lO6pmRTD97LCP-fLI4TMg-7nAeEysT0BF4o1gTPRubUW87vbMxQfnalyDrnljUfLfg3QWebrj11FR6YsQVzcxiKyOFm9wCSETTViPtK30t-9U-puywdtDuXkhJB7bGcA-C0y1Zy5nnHaqpodHPlKwhQ9AWGDfXzxISKvilO8b7g4yQE--wVDvm7MAMM_hiOtQXBDME1WudnDAxfc8e3pFm_yJP8IsEcAiVZbvTgEvKAKDb30CCpieoKvNdnUbOE8_J5cHImeips0qt4Se_VbqRShNeNghJpVhNM2o-IL0VGNEna3GMs5bON0bM8W6EvKHU6a8tgW8BFxDglJfvdcqUNOIW6-rqUC8cbwzkIgbFgiSxcw4W9jFVseui5D5WkTFnpRgNkq5_GBTA6fPcyF8URQl_F1RLUJLgEe8YX_O9msqdK9lJYy47CVFocknLOvYTAp13D6-RJTfGxwBAty5G2vBxCILqiIgTZhEywHTwuvbyVj7j6VcV8q8WutL8SOh1TSLbghk9d8zUC6D0FvQ9qOD_1fS0g3qg2y8rMthkQc785V_HQdZVFIrPKnvElMmbHiXcCF1CV3Bla8xi5KLCV9UGMcO-V5GEclYrS_TKSvHrtJUFQez6mcVSbClP7KUjRoOmyJ7LuXaW8wDISMeONtUXSDrGJq_jO7d4MksddF-ywcEsHRwZ6v8I6BOfPlLbbWSbzo95xFq7BNHV9JRLM-nzB6A5Lk5hmPcMSfOk7nxlDEgO5_mk5szm5WFyQ5FaWp_7PJX9grUpBzcg-ejk5Br7bLwl-OfL-FXvHe9c6K8GHqHy76sAu4QHD5D9CikWvCZiRNQAk_NjjLwjDpB6lQN8S_227v9BZ727LXObXC4Ml7K7Rl_E2z7jg2YV1Up8Egt2A5-_iUF_T7J4MsEo3XaA=w655-h873-no
The Toyota factory service manual recommends using gasoline as the lubricant for the o-rings.
I think silicone grease is the way to go, since that's what MotorWest Performance sends with their injectors and they're experts in the field of injectors.
Very well. At least I didn't add something misleading, so that's good. If I ever need to do an injector job, I'll be sure to keep this in mind. 322K strong and counting!
Motorwest includes a couple extra o-rings also, along with the lube as others have mentioned. You'll be set.
