Full Plasti Dip + Trail Damage!
[MENTION=97733]Fasttimes[/MENTION] just be careful when you clean it. Don't rub so hard as to start peeling in the lighter areas. I would just use a rag, some soap and rinse. If it starts to peel at all I would try to peel it all off or you will have lines. The problem comes when trying to peel not so thick areas, it is a major pain. Best of luck. Check out my thread on plasti-dip, it has some good tips I learned along the way.
http://www.toyota-4runner.org/5th-g...ted-stormtrooper-plastidip-chrome-delete.html
Just got done having a late lunch with Andrew and checking out his handy work. Looks amazing in person and has me thinking about dipping mine. Agree with OP desert tan would look good.
God this looks awesome! Both of your 4runners came out sick [MENTION=50186]adio3x[/MENTION] and [MENTION=66624]KCcarguy[/MENTION] !!! When guys did it did you guys remove your Gobi ladder or where you able to tape it and spray ok underneath it?
Andy, thanks for the tip. when i said peel i meant peel all of it off and start over. i will do as you suggest and clean it then try the spray over. I guess i can always go back and peel it all off and start over if i don;t like it for whatever reason. thanks again.
The layers of dip will bond to each other, so no need to peel it all. Just clean it up and spray.
On a side note, I had been thinking about the desert tan as well. I think it would look badass with the black hood, TE trim and black trail wheels. Maybe sometime in the future.
Andrew, so how many layers did you do?
Ended up doing about 10 thin coats. I'm going to be adding more layers this summer, already planning my next color.
I left everything on, I don't care that much about how it looks to take everything off haha. Just did a good job masking and the DYC gun is pretty cool, it has this misting setting, so if theres any tight areas that are hard to get too, you can change the pattern & angle.
I just taped my entire roof off because I didn't want to mess with it. The black roof looks pretty good with the anthracite. Here's a good shot of my rig from above:
[/URL]~original[/IMG]
That's cool about the DYC gun. I had trouble maintaining a consistent texture in the tight spots. Also had issues keeping a smooth texture on my hood because I didn't have the reach to maintain a perfect angle.
Just found this thead and it solidified my decision to plastidip my entire 4runner. I has a question about your spray sequence to achieve the same color and finish as your rig. You said you used 2 gallons of black, and 1.5 gallons of 50% black and 50% glossifier. I was wondering about how many coats of each did you apply? Thanks.
[MENTION=50186]adio3x[/MENTION], how much did spray gun and all that dip cost?
if you don't mind me asking....
want to see if it is worth the time and stress of potentially messing up a paint job, or just paying someone to do it.
Cheers
Cheers
wondering the same thing... there is a body and paint shop across the street from my house, if I buy the plastidip I wonder if it'd be the same price or cheaper to have a shop do it vs buying the stuff and possibly messing up.
my biggest concern is artifacts getting between the wrap (dip) and the original paint. I have no scratches in the main body right now and want to preserve that as long as I can. there are some rock chips in the hood from a trip to CO, but nothing too major to drive me insane...
I bought this kit, you'll need at least 5 gallons to do the 4runner. I ended up doing a little less without the roof & bumpers (also didn't do thick enough coats). It looks fine, the only drawback to doing thin coats is it's not so easy to peel off. But I plan on changing the color, so the peeling isn't an issue anymore.
https://www.dipyourcar.com/ProfessionalCarKitTruckSUV.html
You can get everything on that site. Also watch all the videos on youtube. Honestly it wasn't a hard task, you just have to be patient. I got quoted for a full dip job minus the roof from a dip expert in town & they were going to charge $1600.......... NOPE! If you can park your 4runner in a garage for 10 hours, do it yourself.
Really considering doing this asap...Couple questions.
1. Did you have any dings in the runner? Only asking because I am wondering if those dings still came through, and/or did it make the applying process any harder?
2. Did you sand your car with all those scratches, or just let it go?
3. How is it holding up. I've plastidipped my wheels and it held up for about 3 years under some brutal conditions. I just recently redid them and looking as clean as ever!
4. Would you do anything differently in applying the dip?
Thanks, Cheers!
P.S. That rig is soo sick...envy you man.
[MENTION=114214]Kirklandak11[/MENTION]
No it's not any harder, the dip adheres to the body like spray paint. I had a crease in my door and one on my passenger quarter panel from being pinned in between two trees, you can barely see that there is a crease after the dip.
Sorry I don't have a good pic from that side, I'll get one when I have a chance.
No sanding, those scratches were very light (surprisingly after the amount of brush I went through), after a coat of simple green, they disappeared. Scratches that go all the way through the dig can be fixed by using a paint thinner and respraying those areas.
It's still holding up great! People are very surprised by it. Here in Missouri our trails are very tight and very woody. I thought it was going to look like a zebra the first time out, but it's holding up very well against the abuse.
The only thing I would do differently is the window trim. I would mask the doors (run plastic wrapping on the inside). So dip the door, and while thats still wet, dip above the door where the trim is and even the door jams. That was my biggest problem, where the trim meets the doors, came out really crappy, so I went back in with a can and did the jams, the color is a little off but whatever lol.
I've been thinking about doing my hood and wheels. price from a local Plasticdip sprayer, was quoted: Hood $150, Wheels $150.
Over 2 years later, how's this holding up?
It's been a little over 3 years and it's holding up for the most part lol. The only places that it's starting to peel are places close to edges (albeit those places were hard to dip in the first place). Areas like above the window trim, A pillars, side mirrors are the worst, but besides those parts, everywhere else is intact. I'll try to get some photos together. It definitely does not look very good haha, originally was a satin black, now looks more like a faded grey covered in dirt lol.
Good to see you back Andrew! Man you are getting old lol.
It's been a little over 3 years and it's holding up for the most part lol. It definitely does not look very good haha, originally was a satin black, now looks more like a faded grey covered in dirt lol.
I noticed this as well. The month I bought mine almost 5 years ago i dipped all the chrome handles/grill/rear trim. It surprisingly has held up great with the only thing being it is a little harder to clean I've noticed. I will probably touch up this summer.
