Full Prinsu rack without drilling?
PhotogEric
I read somewhere where people are using a spacer to sit the front of the rack on instead of drilling into the roof. I can’t find that thread anymore, so is there anyone here who’s done it? Where did you get the spacers from, and what size? Thanks!
Did you end up doing the same and how did it work out?
Sorry for the delayed response.
I ended up drilling it in.... The only reason is because I bought a Smittybilt XL roof top tent, and it takes up almost the whole rack. I figured I should just drill it for the extra support, and less stress on the bolts at the back of the rack.
Honestly, drilling it was pretty easy. And it doesn't leak at all. If I wanted to take it off, I could easily seal up the holes and get new pieces of weather striping to cover it up and no one would ever know.
But If I didn't have the tent, I would feel comfortable not drilling. Its solid.
I just got my rubber feet in for the front of mine, I am having a hell of time trying to keep the hex head bolt from spinning inside of the rubber foot while tightening down the nylon lock nut on top. It's pretty secure but I can still ever so slightly move the foot around within the rack bracket. I will see if there is any movement once I have the rack mounted on the roof with the middle and rear mounts fully tightened. Any pointers on how to keep the bolt from spinning inside of the foot would be greatly appreciated (I've already tried holding it tightly with vice grips).
For those of you who have gone this route, which height/size spacers did you use for the center and rear mounts? I only have (6) of the shorter .75" spacers and (4) of the taller 1" spacers so it isn't possible to use one size for all of the mounts. I am thinking that I should go with the taller ones in the rear and the shorter ones in the middle and possibly stack a washer underneath the middle ones to bring them close to the same height as the taller ones in the rear. I plan to use rubber washers under all of the spacers between them and the roof of the 4Runner, I've also heat-shrink wrapped the spacers to help with absorption and to keep them black without having to paint or powder coat them.
I have no plans of mounting a RTT on this vehicle so I didn't see the need to drill, it'll hold Maxtrax and a 4-gallon Fuel Rotopax on most trips and possibly an Alu-box or two occasionally.
Did a no drill with rubber feet today. Very sturdy without being drilled but time will tell. Rack wont be used too intensely so it will definitely be adequate
Where’d you get these?
Any issues? Updates?
Anyone have any issues? or has installed a RTT? I have had it on with spacers, but having some wait up there (200 lbs) im worried about driving around with it on.
I wouldn't worry about it as long as you have those rubber feet or something similar on the fronts.
There are new ones that are non drill and come with feet that mount with 3m tape into the little gutter now.
AndiGarage
