Thanks for the info the help. I figured everything out. I found a ground connection that I never really touched was loose. Tighten that up and that took care of the battery issue. Unfortunately because of it I had to buy a new battery. As for the ABS, traction control, and the multi terrain light, it was because I had the DRL fuse head plugged into the side heating mirror like the instruction and video said. Instead removed it and put it in the injector slot and now have no problem. The DRL isn’t working but it seems like a common problem with DRL harness they gave. Will contact Morimoto for technical support
Final update. After a nightmare of a start to the install and blown fuses and electrical shorts and and crap, I finally got everything working as advertise including the DRL. Headlight revolution install video on YouTube wants you to put the fuse tab in the side mirror head slot. I would not suggest that cause it cause a short on my rig and also caused the ABS, traction control, mulit terrain light all to come on including the airbag light. Stick with the Morimoto instruction by installing it in the INJ slot. If you have raptor lights in that slot you might want to relocate that to the side mirror heat slot instead and see if it works for you. The DRL harness I received upon further inspection of it had an actual pinch under the sleeve of the wire. I was able to repair it and put heat shrink wrap on it and it took car of the problem. Let see how these guys do from this point on.
