Good Grease Gun
JMG73072
I've had many and my current is one by Lucas oil and now I get grease everywhere except in the zerk. So, what do you all use and how do you like it? I'd be willing to spend 100.00 for a quality tool.
Where is it leaking from? I have used Home depot specials all the way to the professional guns (not sure of the brand but they are $100+ )the guys use at work and never had any leak.
A lot of it has to do with the grease. Mobil 1 pink stuff separates after time and will find a way to ooze out of pretty much any gun.
That said, if you want a quality Made in USA product that will last for generations, check out Alemite Heavy Duty series.
This, what we use at work for greasing fin fans and motors. Our operators cannot destroy them.
77
I have one general recommendation and that is to purchase a grease gun with a pistol grip. Makes it a whole lot easier when greasing those hard to reach zerks like on the driveshaft and when a third hand would be useful. And makes it much easier to keep pressure on the fitting and avoid those grease blobs.
I did a bit of research before buying a grease gun and after searching on garage forums etc I ordered the MacNaught grease gun. Made in Australia and reasonably priced for a quality grease gun at $50. It's been working great.
Flexigun Pistol Grease Gun (14.5 oz cartridge)
Also may want to try this grease, it doesn't separate as bad as the pink Mobil1
Green Grease | The Best Grease Money Can Buy!
If you can swing the price for an Alemite Heavy Duty then go for it, however it's around $130 and not pistol grip. Alemite has a good name and they used to all be made in the USA but they started making their lower models in China. Only these Alemite models are made in the USA:
Heavy duty series- Lever
Heavy Duty series -Extra Long Solid Lever
High Pressure Series
C 600
