Good shop in Central Florida for a suspension installation?
joeee128
As title says. Preferably in Orlando. Looking to do a Icon stage 5 or 6 on a 2013 Trail. Any suggestions?
I have the the tools and space to do it myself but my experience with off-road suspension (and welding - as is required for a stage 6) is limited.
After reading some posts I've come to the conclusion an installation should cost around $800 - does this seem accurate?
What in a stage 6 requires welding? Looks like UCAs, coilovers, rear coils, upper and lower rear arms, plus track bar. Should be able to DIY with a little guidance from previous installs that are documented in this forum.
Seems like a big waste of money if you live in Florida, anyway (I used to live in Tampa).
If it is what Jeremy said, I would just do it myself especially since the coilovers are already assembled. Probably take six hours.
I have a good friend that works at David maus toyota. He does some stuff for TW members all the time. What do you need welded?
There's several places in Florida that warrant a good suspension.
I travel to the good stuff. When I first got the truck (literally) I took it on a 3 month 10 days cross country trip. I went off road in Sedona, Las Vegas Red Rocks, Los Padres, Big sur, Anza Berrego, Baja Mexico and countless other places. After putting the stock suspension components (and skid plates) through their paces, I've decided that ground clearance is a good idea for future trips.
Perhaps my understanding of the Stage 6 is inaccurate but doesn't a secondary shock in the front require the welding of a mounting platform to the frame? I sourced this information from 4funr.com. It seems to me that the Stage 6 system is the setup that includes a second shock... is this accurate?
My first ambitions were to do only the necessary modifications needed in order to put on taller tires - 33"s. However, after reading about the people who started off modest and 'evolved' to better and more expensive suspension system complain about how they wish they had 'done it right the first time,' I have been convinced that aiming high isn't the worst thing I could do.
I am still in consideration and could probably be talked into something less intense especially if it is cheaper. A large factor at play with this thought is that I've done quite a bit with the stock setup and I've managed to realize first hand that a slow approach and a good spotter are really the best off-roading strategies.
Incidentally, the worst damage my vehicle has sustained was on the back trails of Chassahowitzka in Florida. I ripped off the front driver side mud flap reversing out of a impassable trail. This was a product of being impatient and not having a spotter. It's also the closest to date I've come to getting stuck.
If you're more of an expedition guy you probably don't need an extra bypass up front. If however, you like high speed stuff than it might be useful. Regardless I'm not a fan of the way icon made the system. That fact that its mostly bolt on is just scary and begging for trouble. If I were you I would check out TC's site and look at their spindle, cam tab, and shock tower gussets along with their stock length LCA's and secondary hoop. But at that point you might as well look into their +2" LT kit.
Stage 6 doesn't have secondary shocks, just resis. The LCA skid, secondary shock hoop, and secondary shocks are all separate components, and supposedly all bolt on with some minor modification.
Not that many people that really go all out on suspension, most I think are happy with the lower stages and other aftermarket setups; they just don't have great build threads full of sexy hardware.
Let me know if you find someone reliable
I am slow moving but eventually I will install a lift kit. I am looking at something simpler, like the stage 2 long travel kit from Metaltech with Light Racing UCAs. If you find someone good to do the work in the Orlando area let me know. I have looked around quite a bit but really have not come up with anybody that seemed to really know what they were doing. If it comes down to it I will do it myself but I would love to find someone more knowledgeable that could also perform a proper alignment at the same time.
I would suggest to you and the OP that you join TW and introduce yourselves in the FL section (specifically the BS thread). There's plenty of us in Orlando that have the tools and know how to do just about anything.
Wow! That's a generous offer! Very gracious of you...
David
Preparing for Success
Not the OP but also located in Central Florida with an approach to fix or minimize the stated issue above.
My 4Runner is scheduled for full suspension installation by a well-regarded Japanese speed shop early next week.
I want to make sure I've set their mechanics up for success - and make it very hard for them to miss or ignore steps, by providing just the right amount of information they need to perform a successful install. As a non-mechanical person, I understand that while I've read the How To: Lift Installation (on KDSS equipped vehicles) 20 times, or any of the other countless valuable threads here, I can't expect them to really give any of them a deep reading.
All instruction manuals and consumables will be dropped off with the kit, but if you were about to turn your vehicle and suspension kit over for a professional to install, is there anything you would want included on here?
Page 1
Page 2
Additional Measurements
peacefulpiranha
