Okay here's what we'll do... Forget about JL's directions for now; I use another method anyway. First, turn the amplifier's gain control
"all the way down" (counter clockwise). Now find a piece of music in your collection that's represents what type of music that you like to listen to; nothing with any exaggerated bass track e.g., Rapp, Hip-Hop, Reggae... nor anything that the bass is barely audible in the track e.g., classical, opera... Okay, now with the sub's speakers connected, adjust the HU's
Treble & Mid settings to the middle position: (
-llll
-l-llll
+) and for the bass it should look like this (
-llll-0-llll
+); The bass is all the way in the negative!
Now turn the HU's volume control
"3/4 of the way up" which has a numeric value of 42! Check and make sure that your LOC i.e.
Line Output Converter is properly set; Mine is set to three quarters of it's maximum level. Now from zero, using the amp's
Gain control, begin to increase the bass level just until the bass begins to dominate the sound coming the other speakers (we're doing this so that you'll have slightly more bass gain than you will actually ever need no matter what choice of music you're listening to)!
NOTE: It's
'EXTREMELY' important that you're feeding the mono-block enough voltage from the HU's
Left and Right FRONT speaker channels to drive the amp to it's full rated output; if you're not connecting both the left and the right
FRONT speaker channels your amp can only produce
Half of it's full rated output!
BTW: that amplifier has a selector switch on it's front control panel (Low & High); The high setting is there just in case you need to use the speaker out wires from a very high wattage HU i.e., (50W each channel or more!); but assumming that you're still using the stock HU, this feature does not apply!
And then there's the low level input switch mode, which is to be used to accommodate an
RCA low voltage line signal outputs from the HU's pre-amp stages; which is measured in mA (for milliamps) less than one volt. You will want to select that option because of the very low power levels that the stock
'Panasonic' hu produces! (I'll bet that's your problem!)
IMPORTANT: If you're not using a
'Remote bass level volume control' near the driver seat be sure to install one because all program material is very different, and so the sub's gain level is constantly in need of adjustment; it's impossible to find one setting that will work on every piece of music program at all volume levels.
You can either use (if available) the JL Audio's 'integrated' remote level control phone jack on the amp's control panel (Left)
https://www.amazon.com/JL-Audio-HD-...&sr=8-2&keywords=jl+audio+remote+bass+control, or you can use what I've had to use with my
Alpine PDX-M12 Series mono-block subwoofer amp; which is a conventional line level voltage control like the one on the right:
https://www.amazon.com/Skar-Audio-G...14&sr=1-11&keywords=remote+bass+level+control
Corey... I'm certain that the problem is only that the amp is being starved for proper program signal; either you're not combining both the
L & R channels, in which case you're only utilizing one half of the needed signal, or, the
LOC is not adjusted properly and trimmed back too much: If you look at the LOC device closely you'll see two holes; that's where the two adjustment potentiometers are located. Simply insert a small pocket flathead screwdriver and turn the two screwheads clockwise to the three quarter position to increase the signal feeding the power amp. Please be sure to let me know how you make out with this so we can officially cross this off as a
Problem solved file!
Best to you'!
