Ground wire question
Drcoffee
Senior Member
I am making up a new battery ground cable to ground to the engine block. I plan to use a copper eyelet lug at the end of the cable to bolt it to the iron engine block. Is there going to be a reaction between the copper connector and engine block? Should I use an Aluminum crush washer between the copper a iron?
I plan to use a little dielectric grease on the contact points. I was afraid it would corrode and break contact over time. Thx
pax at 4
