Group buy : DC power Engineering 270amp alternator
[MENTION=137485]CrazyMike[/MENTION] & [MENTION=124732]LawnDart[/MENTION],
Don't forget, these aluminum billet housings (End-frames) are forged/lathed to every specific detail. None of their alternators are rebuilt or salvaged, cleaned-up and relabeled new. I'm sure that they'll get hold of the 2015/2016 blueprints for you the very same way they did for me Built from scratch; SO HANG-IN-THERE!!!
rig
As long as the group buy price is still valid when a 2015+ model is made available I'll be happy, but for now I guess I'm out because it won't fit. So please keep us in the loop if/when it does.
[MENTION=124732]LawnDart[/MENTION] running out of money from all the other upgrades :hail: ......I kid , I kid.
I see you are not the only one so hopefully , in time, they are able to source the connector they need. Sounds like we need to update some threads about "differences between model years).
I always knew my 2014 was the best year, alternator connector, more than just a clock in the center dash display....etc, etc
until then....suck on these AMPS :bigok:
Update:
I called my local dealer today and spoke to them and they told me that the alternators are the same from 2010 to 2016, (no word on 2017 yet) I ordered an alternator from them for a 2016 just to verify there are no changes. The alternator will be here Monday morning and I will update this again. We should be in the clear, but I like to be 100% sure :P.
Thanks guys!
Update:
Thanks guys!
Excellent! Thank you for the update and quick response [MENTION=144561]DCPower_Anthony[/MENTION] - I had planned to order tonight after work, but will standby for your update and order accordingly.
Looking forward to it!
Not a problem, thanks everyone for their patience.
All e-mails sent in regarding current orders have been replied back to. If you ordered your alternator already and haven't sent in an e-mail to [email protected] to confirm your Year/Make/Model/Liter Motor please do so at your earliest convenience.
If it's just a difference in plugs, this could possibly be an easy fix, right? I'm hoping that's the case and would like to get in the group buy. Would be interesting what plugs would be on the 17's as well.
Sit tight guys. If you haven't seen the message from Anthony above just yet, it is looking positive for the 2015/2016. Please keep checking back for details.
Okki
hey guys, I'm interested for my 2016 Trail Premium to power a Warn Winch, light bars and dual battery set up. Will this work well for that?
Hi Obi Wong Kenobi,
I agree with you; how hard would it be to go to a Toyota dealership and ask the parts counter person to let you see a 2016 4Runner alternator to match the electrical harness input connector? ...pretty sure the electrical manual will reveal if this alternator is ECU/PCM controlled or only monitored, the number of pins and what each one does.
"I remember and old mechanic (a mentor) used to tell me... "There's always a way son; don't let anyone tell ya no different!"
'Best'!
Hey Rig,
Doesn't look to be a big deal to swap out, slightly tight quarters but what they hey it's not my first rodeo turning a wrench................
Forgot to mention, told you this was on my "to do" list back when you made the switch, just late to the party...............again!
(lol) Hey Barry,
The only reason I had a shop do mine for me was because when the alternator 'finally arrived', we got hit with another 18 inches of snow on top of the snow that I had been waiting to melt! But I was at the shop when my mechanic made the swap and there were no particular obstacles once you knew that there was a third bolt underneath the alternator, connecting it to the left exhaust manifold!
Cheers!
Added you to the 2015/2016 batch. :thumb:
Your question has been answered earlier in this thread. Please scroll back a page or two :). Short answer : Yes, this will charge your dual batteries very nicely.
Thanks!
Okki
Hi Obi Wong Kenobi,
'Best'!
Toyota has switched over to a LIN controlled regulator or a COM regulator and so has Honda. It's one pin that is controlled by the PCM
Picture here:
The old plug was a 4 pin connector:
Which as you can see has 4 pins and those are L (Lamp), IG (Ignition), FR (Field Report), S (Sense).
The single pin connector on the alternator in the first picture is from a 2016 Toyota Tacoma 4.0. SO that was why I had my doubts they were the same alternator from 2010 to 2016. I thought the Tacoma and 4Runner would of shared the same 4.0 liter?
Thanks guys
Picture here:
Thanks guys
Hmm... I'm interested in jumping on the group buy but am leery now if Toyota is changing plugs around. Reason being is this will be part of my stocking up on mods before my 2017 Cement comes in. Maybe since I'm somewhat local, Anthony from DC can work with me if the 17's end up being different if my group buy purchase doesn't work? :)
I can do my best to work with you once the 17's are sorted out :)
Hey guys, this alternator should just be a simple unscrew, swap, rescrew and done on a 2016 4Runner Trail Premium, correct? No change in plugs or any customization required? If so, I'm in.
Thanks guys
Hi Anthony,
And thanks for the that great 'Heads-up'! Now that this has come up, it's triggered a couple of questions:
(1) I wonder if the LIN (for linear??) controlled regulator can be removed and swapped out for a conventional Denso analog regulator, or...
(2) If an interface module can be connected to that LIN 'single pin' connector and then there would be a four pin connector on the interface module input side for a simple 'plug-n-play' installation.
"...it'd be nice if I still had my stock 'Denso' 130A alternator (sold it soon after I purchased the 270-XP), and the newer model (2016) 130A so I could take them both apart and see just what parts are interchangeable. Then I could see how to get around the recently modified 'single pin' Denso 130!" Once again Anthony, thanks for all your help and the info!
rig, Cheers
[MENTION=144561]DCPower_Anthony[/MENTION] , doesn't look like it was addressed so just wanted to say FYI that the 2016 Tacoma's have a different engine than the 2010-2017 4runners. 3.5 vs 4.0 + many others, I don't think its even the same family.
I've previously upgraded my distribution system and have been looking to do this upgrade. Could I get on the list for the 2015/2016?
Runvod
