barryhiram
Done! Top slot on batch 3!:whoo:
Okki
SWEET Okki!
Okki
[MENTION=137485]CrazyMike[/MENTION] & [MENTION=124732]LawnDart[/MENTION],
Don't forget, these aluminum billet housings (End-frames) are forged/lathed to every specific detail. None of their alternators are rebuilt or salvaged, cleaned-up and relabeled new. I'm sure that they'll get hold of the 2015/2016 blueprints for you the very same way they did for me Built from scratch; SO HANG-IN-THERE!!!
rig
As long as the group buy price is still valid when a 2015+ model is made available I'll be happy, but for now I guess I'm out because it won't fit. So please keep us in the loop if/when it does.
Update:
I called my local dealer today and spoke to them and they told me that the alternators are the same from 2010 to 2016, (no word on 2017 yet) I ordered an alternator from them for a 2016 just to verify there are no changes. The alternator will be here Monday morning and I will update this again. We should be in the clear, but I like to be 100% sure.
Thanks guys!
Excellent! Thank you for the update and quick response [MENTION=144561]DCPower_Anthony[/MENTION] - I had planned to order tonight after work, but will standby for your update and order accordingly.
Looking forward to it!
If it's just a difference in plugs, this could possibly be an easy fix, right? I'm hoping that's the case and would like to get in the group buy. Would be interesting what plugs would be on the 17's as well.
Hey Rig,
Doesn't look to be a big deal to swap out, slightly tight quarters but what they hey it's not my first rodeo turning a wrench................
Forgot to mention, told you this was on my "to do" list back when you made the switch, just late to the party...............again!
hey guys, I'm interested for my 2016 Trail Premium to power a Warn Winch, light bars and dual battery set up. Will this work well for that?
Hi Obi Wong Kenobi,
I agree with you; how hard would it be to go to a Toyota dealership and ask the parts counter person to let you see a 2016 4Runner alternator to match the electrical harness input connector? ...pretty sure the electrical manual will reveal if this alternator is ECU/PCM controlled or only monitored, the number of pins and what each one does.
"I remember and old mechanic (a mentor) used to tell me... "There's always a way son; don't let anyone tell ya no different!"
'Best'!
Toyota has switched over to a LIN controlled regulator or a COM regulator and so has Honda. It's one pin that is controlled by the PCM
Picture here:
The old plug was a 4 pin connector:
Which as you can see has 4 pins and those are L (Lamp), IG (Ignition), FR (Field Report), S (Sense).
The single pin connector on the alternator in the first picture is from a 2016 Toyota Tacoma 4.0. SO that was why I had my doubts they were the same alternator from 2010 to 2016. I thought the Tacoma and 4Runner would of shared the same 4.0 liter?
Thanks guys
Hmm... I'm interested in jumping on the group buy but am leery now if Toyota is changing plugs around. Reason being is this will be part of my stocking up on mods before my 2017 Cement comes in. Maybe since I'm somewhat local, Anthony from DC can work with me if the 17's end up being different if my group buy purchase doesn't work?![]()
Hey guys, this alternator should just be a simple unscrew, swap, rescrew and done on a 2016 4Runner Trail Premium, correct? No change in plugs or any customization required? If so, I'm in.
Thanks guys
I've previously upgraded my distribution system and have been looking to do this upgrade. Could I get on the list for the 2015/2016?
