Handgun in the 4R
Status
Not open for further replies.
G26 is a sweet shooter.... just getcha a couple g19 mags and you will be golden. I also highly recommend replacing the mag release with a vickers tactical release and a nice set of sight (Trijicon HDs are titties for glocks)
Well, thanks for all the feedback guys. I've decided on something smaller to carry and more importantly conceal, a glock 26 9mm. For now, keeping it in an old computer case I had lying around, it has locks on the front and the side. Looking around for a better lockable gun case.
20130106_194020.jpg~original
My wife could rack it relatively easy so I could pass it on to her when I get another pistol :) It really is an expensive addicition! And ammo is really hard to come by!
Once again, thanks gents!
Dude that's a pretty cool little hiding spot!
Personally, I love Sig Sauer. I have a P220 (.45 Auto) and P226 (9mm) and spend quite a bit of time with both of them at the range. So those are the two pistols I have the most experience with and have nothing but good things to say about. Now, I don't carry a firearm (although I think I probably should start, the world seems to be getting crazier every day) but I think that the single double action is a great asset for a CCW and just a firearm in general. The single double action isnt for everyone, but I highly reccomend that people "test drive" it to see if they like it. There's lots of great pistols out there, but I thought I'd just do a little lovin' on the Sigs...
You ever have problems with Jams? I think one of my mags is bad, which name brand mags do you recommend?
"The trigger break on a Glock or Springfield XD(M) is much less predictable and the shot goes off as somewhat of a surprise to your brain,"
I'm not sure how a trigger release could be unpredictable. These are modern guns we are talking about. There may be some differences between different guns but one gun, one trigger, it should be as predictable as any 1911.
By less predictable, I assume you mean that there is no "constant pressure feel" of the trigger as the slack is taken up and the gun fires? This gives the sensation that the Glock trigger is sloppy, but the gun will fire at precisely the same point every single time.
To remedy this try a combination of a New York Trigger Spring (Olive) and a 3.5# Connector (-). The resulting poundage will remain virtually the same, but you will get that constant tension that you desire.
Standard Trigger Pull = 5.5
3.5# Connector + Factory Coil Spring = 3.5
NY Trigger Spring + Standard Connector = 8
NY Trigger Spring + 3.5# Connector = 6
:uzi:
I have a couple Sig's and can't even tell you how many rounds I have fired through them.....thousands. Never one jam. I use the Sig mag's.
I'm hitting the range tomorrow!
My M&Ps have never jammed either. Well, except when empty shells were loaded (mixed with live rounds). This is a great practice to know what to do WHEN you gun does jam.
That's now made in the :usa2:
So is a tundra, but we bought 4runners.
Sig, glock, Hk, etc, did this to get around importation laws, not hire Americans.
Where does the money go in either case?
Not trying to be all righteous indignant, but it wasn't much of a case against markarov.
And yes I love my hk's and my sigs.
Owned a g19. Great gun. Current carry is FNH FNP9 and I really like it. A little bigger than the g19 but I highly recommend it for the money. 480ish when i bought it plus FFL 35 and shipping 20. It came with nice box two mags and lock. Also, since its less expensive, you tend to every day use it more than you would something really nice. If youre looking for match grade barrel and high dollar stuff then I'd recommend listen to some of the other guys.
What is going to happen to the 2nd Amendment? I haven't head a single person talking about sending the government door to door to confiscate our guns.
New York Governor Cuomo has talked about it http://m.townhall.com/tipsheet/kati...vernor-gun-confiscation-on-the-table-n1472196
The 2nd Amendment says "shall not be infringed." I live in a state that has an Assault Weapons Ban. In my mind, that certainly does infringe on my rights, and a nationwide ban would infringe on the rights of many more citizens.
New York Governor Cuomo has talked about it Katie Pavlich - New York Governor: Gun Confiscation on the Table
Really? What state is that? So because you can't buy an "AR-15" your panties are all in a bundle and you feel you are being "infringed?"
What have you done prior to the Newtown shooting to protest the loss of your rights? You know what I thing; I bet you are just fine! My point to this is that some of us really need to get a grip...
Status
Cpn2mss
