Hands Feee phone
Newowner
I have been trying unsucessfully to transfer my Blackberry addres book data into the hands free phone's phone book. I can connect via the Bluetooth connection but when I go to transfer the data, the Bluetooth connection is lost. Any ideas as to why?
PS I too am mightly peeved that the override function is no more. Its nice to have the passenger able to manipulate the systerm while in motion!
What provider do you have? I can't transfer the phonebook from my Verizon phone to the nav.
I am not completely sure about this, but from what I have read blackberry bluetooth stack is pretty secure and locked down. (I have an 8700g and done some experimentation with it.) I am not sure if anything can access the address book over bluetooth. I have paired up my blackberry for hands free use with the 4th gen toyota NAV, but did not access the address book.
check
http://www.blackberryforums.com
Contrary to what carriers tell customers and faulting the automaker or manufacturer of the Bluetooth kit, it lies in the phone/handset and the carrier themselves for having the handset locked down. Verizon recently settled a class action suit over it.
Sprint says the Treo650 isn't compatible with certain Bluetooth headsets and Denso (Toyota/Lexus) BT kits. They determine compatibility based on call quaility and if it interfaces with the phone. My Treo650 works perfectly with the nav, never loosing the connection or dropping the call. I can make calls off the nav dial pad or by voice command. The only gripe I have is I can't transfer contacts at once, I have transfer one entry at a time.
See if the Blackberry will allow you to transfer each entry individually. That worked with the Treo650. A real PITA for 100+ entires, so I just loaded the folks who I call the most in speed dial and the rest I just dial them off the Treo. Not a completely hands free solution, but answering calls is more important.
