I've been looking around for some time for a "reasonable " priced set of alloy rims that will fit over the 231mm rotors. I can't find any rims locally, even unaffordable! I even went down across the line (USA) to Wash. and was able to find unaffordable ones... I was able to find some online but shipping kills! At that time, I liked the 4runner 5- spoke and "flower" rims off the LTD's. However, this search has been unsuccessful. Therefore, I looked for 16" rims off of Tundras and Sequoias. It stands to reason that all the rims off of these trucks will fit as this is where the 231's came from! However I didn't have much success here either, as there isn't that many of them around! So now I come to Tacoma's. These trucks are far more plentiful and have quite a few different rim combinations, however, these trucks have basically the same brake setup as a 4Runner...
So, does anyone know if this rim will fit? As above, its off a late model Taco...
So, m
I know these wheels will not work with the 231mm but is it really safe to grind the inside of the wheels? And how do I grind the wheels? Running on a budget and my steering wheels is vibrating like crazy now since six months ago. I need to change the rotors and brake pad so I would rather upgrade to the 231mm. I might just go with the 199mm if the 231mm does not work out for me but is the 199mm really worth it? Or should I just keep the stock calipers and just change the rotors and brake pads.
Plus I will be going on a roadtrip at the Sierras and need reliable brakes. Thanks for any help! I will need it =D
With the wheel spacers you should be good. The caliper hits on the wheel because it sticks out too far outboard.
And I would strongly urge you not to grind on the wheels, either get a set of spacers or some new wheels. I think the guy that did grind is only using that wheel for his spare.
Tell me how the 1.25 wheel spacers go! =D I found someone selling new 2006 stock tundra wheels for $250. I might just buy the wheels but do not know if my 4runner tires will fit on the new wheels
the tundra wheels are 17 inand my 4runner tires are 265/70/16
$250 for stock Tundra wheels--- That's a fantastic deal! The cheapest deal I've found is $100 a rim, for older ones... plus shipping! I was thinking of trying spacers, however, I have no experience with them and have heard that using them can affect handling... can anyone comment? Plus, I'm not crazy about having to trim the wheel studs...
