BoomSticks
Member
When Callahan auto parts (especially brake parts) were first mentioned, I thought we were about to be rick-rolled with Tommy Boy references.
Snagged a Callahan TBU kit for $275 this morning: https://smile.amazon.com/FRONT-Cali...&qid=1469044075&sr=8-1&keywords=13wl+callahan
Reviews of Callahan seem to be good, the brand is owned by Powerstop apparently. I needed new brakes regardless, so I mostly just wanted the calipers since the pads and rotors can be replaced cheaply. I should be able to give first hand experience in a week or two.
Guys. I have a pair of 231mm calipers for sale. 1 is rebuilt. The other has a seized piston and all the new rubbers for it once the piston comes out.
I need to sell these. $50 shipped. Spend some time to get a piston out and you have new rebuilt calipers.
pm'ed. How hard is it to get that piston out? Can I get it done at a machine shop?
Link no worky, anyone have a working link?
FRONT Red [2] Calipers + [2] Rotors + Quiet Low Dust [4] Ceramic Pads Performance Kit https://www.amazon.com/dp/B00EOBMFAY/ref=cm_sw_r_cp_api_GLYXxbY804T6T
Snagged these when they reappeared for $206 shipped. I ordered them three days ago and they just arrived in good shape. Local shop is going to install the set and do a flush for $300. If all goes well, $506 seems like a bargain for getting rid of my wavy rotors. Anyways, looks like they're backed up to 275, but still seems like a great deal.
Yeah. Actually what I was planning on doing was putting the caliper on my truck. Then putting a block of wood between the 2 other pistons and a c clamp to hold the third then push on the brakes and use the truck to push the piston out.
If you follow that madness. But I just what them out of my office.
[MENTION=72511]thor999[/MENTION] There you go, they're back.
Same thing happened to me! I soaked it well, put a wooden block into the free side, clamped the opposite piston and hit it with compressed air. I worked it for some time and when it let go, it really popped. You might want to to consider finding another one if you can-- when I had a look at the caliper and piston, I ended up having to polish the cylinder and piston for a while to get the corrosion off.
How is this kit? Is it good? Reliable? Or better to get used OEM and rebuild it ?? Are they the big tundra?
My problem now, and would very much like as much advice as you can offer! (Bought these from shootmymime)
Just the time needed to do them right is all that is keeping me from it. I have to hang siding and new windows and doors on my 2400 sq. ft. house then paint, all before it gets too cold out.I saw your post below and I understand wanting to get it done. I had plenty of time and empty work bench space so I worked on them when I got a chance, over a week. I got my calipers cheap from a wrecker (I did have to return one as it had a broken bleeder, luckily they had several). I soaked both for almost 48 hrs in "Metal Rescue" a rust removing bath and scrubbed them. I then returned them to the bench and hit them with compressed air to remove the pistons. If you saw my previous post, I had a bit of a chore getting one piston out, as described. I basically, braced all the pistons and hit it with compressed air, working it back and forth and slowly it started to move. Once I got it out, I spent an eternity polishing the pistons then the bores with a fibre pot scrubber (not steel wool) to a near mirror finish and until the bores had no marks or scoring. I then put some brake fluid on the pistons and slide them into the bores to ensure then slide smoothly (with seals). I then re-assembled them, taped them up and applied 2 coats of Coroseal (rust converter primer), 2 coats of primer, 2 coats of paint. It was alot of effort but I was happy with the result.
