Headlight and Fog Light Upgrade Suggestions
hrantvarozian
We often drive from LA to Kern River on Friday night so upgrading my headlights will make a drastic difference on visibility during the drive.
I want to focus on making the high-beams and the fog lights really bright. I wouldn't mind upgrading the headlights but I don't want to put anything in that will blind normal car drivers when my headlights are in their rear-view mirrors.
I was contemplating putting in a light bar but I just won't use it enough. I have a 3 year old so any off-roading I do is during the day.
Any suggestions would be most appreciated.
Cheers.
I run the Morimoto H11 Low Beams and they are so much better than my stock halogens and even better the cheaper Hikari LED Amazon bulb I had in there. I don't get flashed at all with them either. I disabled my DRLs and run the Morimoto high beams and the Morimoto complete xB Fog Light assemblies. Unbelievable difference!!! They are pricier than the Amazon stuff but better quality and warranty. I got mine from Automotive Lighting & Accessories: HID Kits | LEDs | Audio/Video. Great prices and awesome customer service!!
Running the Morimoto 2.0 H11 low beams and Xenon Depot 9005 Xtreme LED Pro high beams. WORLD of difference and have never been flashed. make sure to adjust your headlights after install.
I’m running XenonDepot led’s and could be happier. I can’t believe how bad the stock bulbs are. I just ordered my high beams today from them too.
I just purchased this combination today. Seemed like a great way to keep the DRLs without blinding people during DAYTIME, like some of the HID ugprades do!
running HID's for low beams
2 IN 1 LEDS for fogs
switch back LED's for corners
PIAA hyper yellow halogens for Hi beams
I'm very happy with this combo.
Xenon Depot HID in my low beam projectors.
Xenon Depot Xtreme LED setup in my high beams.
Baja Design Fogs.
I live in the country with plenty of dark 2 lane roads and have a tinted windshield. I'd do the exact same lighting upgrades again if I had to start over.
general consensus is:
No matter if you go HID or LED, if you stick to a good company w/ proven products, you should see an improvement over stock OEM halogens.
I ended up going with Morimoto bulbs from The Retrofit Source | The Best HID & LED Projector Headlight Upgrades
For the headlight I was told HIDs illuminate better in the projector housing so I got the H11B: Morimoto Elite (HID); 50W; 5500k
For the high beams and fog lights I was told the LEDs are better in the reflector housing so I got the Morimoto 2Stroke 2.0.
The Retrofit Source | The Best HID & LED Projector Headlight Upgrades has a really good website with a ton of information and videos. I recommend doing your research there and then calling them up to discuss your order and questions.
Now I got the installation to do once they arrive. =)
Can I ask why 50W instead of 35W for your low beams? 35W are more than enough and are heaps better than stock
Good thing you went with 5000K, theyre the brightest.
I have 5500k HID's in my lows & 3000k LED's in my fogs - both branded by DDM Tuning out of Huntington Beach (they have an actual store you can go in and work with in person which is awesome). Never one issue after being installed almost 2 years...I get flashed all the time - but no one ever shines their brights at me.
giggity
Let us know if those LED highs flicker at all when running DRL mode :pop2:
I didn't realize that 50w make the lights brighter. I thought that having a bigger ballast would mean it would last longer than the 35w.
Well see how it comes out when I get them. Hopefully I dont get highbeamed for my lights being too bright.
Sent from my SM-G960U using Tapatalk
man, hustlin $1000 headlights every day.
OP: Yeah 50W will be slightly brighter and can change the temp of the bulb vs a 35W ballast. Just make sure to aim your headlights after you put the HIDs in.
Standard aim procedure off the top of my head is make sure you are on level ground and a wall. Pull upto wall 2 ft away. Mark center of your physical headlights on the wall with tape. Reverse 25ft. aim headlights 2 inches below your tape marks.
Wont get flashed.
early 5th gen
Anyone running the Morimotos on a pre facelift early 5th gen? 2012 and looking for more light on low beams but have a more reflector set up than the newer 4Rs. Any experience?
X
