Heater - 4Runner
JeyDee
In my 97' 4Runner the heater has not been working for some time (blows cold air). Both hoses going thru the firewall get hot when the heater knob is on heat. Water valve works fine, A/C also works fine and there's no problem with the thermostat.
Yesterday I was checking under the dash (passenger side) and by chance I found this white plastic mechanism (blend door?) with a little knob. I moved the knob to the other position, heard some vent doors opening, and Voila, like magic, hot air started flowing thru vents. My questions:
1) What is the function of this mechanism? especially since the regular heater control knob on the dashboard can now successfully control the hot/cold air thru the vents.
2) What controls this mechanism (surely one isn't expected to go under the dash to manually move it).
3) Is it ok keep it in this new position, or would I get into other problems.
Appreciate any help!
Re: Bump!?
JeyDee said:
Bump your own threads!
I was bumping it to the top of the new posts for you friend so more would see the post and help you out. I was intrested in the answer too.
next time I will let it go so your question might not get answered.
:mad:
No problem.
Anyways my heater problem turned out to be a slack in the wire that connects the temp control knob to the blend door mechanism (under the dash) which prevented it from opening/closing. Had to open the dash to fix it.
increasedc
