I have the same...weak heat on idle, a little more at higher rpm or under load. Temperature gauge reflects the same, so I am going to replace my t-stat tomorrow. I'm thinking it is stuck open.
As it's getting colder, I finally realized that the heat vents for the back seat are pushing out HOT air but I don't seem to get even half that heat up front. Do the front and back vents work off of the same heat source/core? Is this an issue with the vent doors not opening properly? The cold/hot knob is difficult to turn and makes a "clicks" while doing so, which doesnt seem right to me...
Thanks all
The front and rear hear both work in the same way, they both receive coolant from the engine, the only difference is that the rear gets its air from under the front/passenger seat, so its only recirculating air and isn't bringing in fresh air from outside. So as the passenger compartment heats up the rear heater will also always be receiving warmer air to heat up and pump to the back seats where as your front heater may be getting cold air to heat up from the 'fresh air' setting.
My thoughts: If your rear heater is heating up just fine and your front isn't then your front heater core could have a blockage in it or your temp control knob isn't turning all the way to 'full open' to allow the warm coolant in.
that's not entirely correct, the rear heater has its own heater core, so it does suck in air from the passenger compartment but it gets coolant from the front and brings it to its own heater core and then blows it out. so your rear heat can be hot while your front heat isnt, they are separate.
Thanks all
I'll start by pulling the dash cluster off and check out what the resistance is with the hot/cold knob first. But wouldn't the "doors" be operated by the vent selector knob??? Anyone know if I'll even be able to access the "door or doors"? Also, I noticed there are two lines that look like ac lines headed underneath the passenger seat so it seems like there would be a secondary core for the rear heat. However, those are connected after the valve(?) or whatever it might be that is under the hood at the firewall. That valve appears to fully open and close. I don't know, I'm confused as to what does what and where the heat could be getting stopped up....
thanks all
yes, the rear heat has its own core.
before you start tearing anything apart, check the hoses going to the heater core.
get the rig up to temp, put it as hot as it goes, and the fan on high.
check the heat coming out of the vents, make sure its as warm as its going to get.
then open the hood, and find the 2 heater hoses going into the firewall. carefully grab each one. they should both be HOT. if one is significantly cooler than the other, the restriction is in the core itself.
sometimes you can just reverse the two hoses, to run the water in the other direction to clear it up. but usually, its needs to have a flush done, as I suggested above.
there are also places that will do a pressurized flush, with a machine. but, I would attempt to do it myself with the chemical treatment first.
