Help Any trick to disconnect door lock actuator motor power connector?
stoney
I was trying to use a pocket screw driver to disconnect the power connector to the actuator motor assembly. But even after I inserted the pocket screw driver inside the space, it is still very tight to be disconnected. Any trick here?
Thanks,
--stoney
Anybody? It seems like really easy but I could not disconnect the power connector. Maybe I used the wrong tool?
Ok, I will try to squeeze the tab and pull next time I open the door panel. I guess I followed the instruction in the forum too strictly since every step there was correct and I was afraid to broke anything during the disassembly ...
Thanks,
--stoney
Freddygino324
