Help me remove this connector
atcpup
Can someone please advise on how to remove these pins from this connector. I'm doing an ORS elocker harness install and it requires the number 5 connector (instrument cluster) to be replaced with theirs.
So, I went to the local u pull and brought home the connector to figure it out, that way I wouldn't booger mine up. You have to remove the 2 white plastic guards and then stick a small screwdriver in. What a beech! Anyhow, thought I would pass it along
Yeah. Most toyota connectors have a lock. You have to unlock it. Then stick something skinny while pulling on that wire and it should pull out.
You figured it out before I could comment :) Glad you got it all out though.
AndiGarage
