Help with cv axle 5th gen
I just put Icon tubular control arms, Bilstein 5100s on OME 2885s and the Toytec Diff Spacer. I had the alignment corrected, but now I have a slight "clunk" under low speeds during braking and idle rolling. It doesn't do it in the morning when it is cool outside. It only seems to manifest in the afternoons when it is warm. It feels rotational, and I know the tires aren't catching on anything. Is this similar to your issue?
Miles? Had brakes changed recently? These yota pads are notorious for clunking in the caliper
Sent from my SM-G900V using Tapatalk
Less that 4k miles, and no other changes. For the record, I did get the issue sorted out. Turns out, the driver side uniball bearing on the Icon's is the culprit. I got on the horn with Icon, and we did some hasty troubleshooting. They had a new set of bearings drop-shipped from their supplier. Problem solved.
Good to know, was wondering how they handle warranty type stuff
They were awesome. I was quite relieved because their new bearings aren't exactly cheap either, and considering they now have the Delta Joint, I thought for sure I was in for another spend.
wayblom
