cbuchanan87
Normally I do my own work, but I decided to have the pros do my spacer lift and took it to a local shop that does a lot of trucks. I think they put my rear spacers on wrong but I figured I would ask the experts here before taking it back to them. It looks to me that the spacers were put on the bottom of my rear coil.
I think the rear spacers from kit KT09134BK go on top of the springs and are visible once installed. It looks like the coil is flush with the body mounts. It could be the spacer sits recessed into the body mounts but I'm not sure.
Admittedly, I didn't go check my rear end before taking it to them so I'm not sure if there is a rubber bumper on the bottom of the spring from the factory. Or if this is the Daystar spacer I'm looking at. Can someone with a Daystar kit and/or Limited let me know?
Also, if it is in backwards, does it need to be changed? Or is it inconsequential which side of the spring the spacer is on?
Thank you.
I used the search function but did not find any pics that could answer my question. Thanks again.
Thank you.
