Hi guys could some one help me to fix this issue please, I got a 4 runner 3.4 v6 limited 5SR California specs 2001 which I bough last month, my problem starts with check engine and VSC lights on I had an OBD test it shows A/F sensor p1135 & cylinder 4 back fire after that I did the following repairs:
1- spark plugs
2- spark plugs wires
3- Air filter
4- MAF sensor
5- battery
6- removed the filter inside the converters sine the car is in Yemen
Finally I changed A/F sensor & every thing went ok.
After 7 days I bought a bad fuel and after an hour the check engine and VSC light went on agin and the car suddenly stop working then when I turn it on and it start roughly.
I tried to pull the battery negative off to restart the ECU then the lights go off and return back agin I had it checked it agin it shows P0171 system too lean.
The question why the car stop working when the lights go on.
Really guys I need help this issue is driving me Crazy.
1- spark plugs
3- Air filter
4- MAF sensor
5- battery
