Hood bug guard?
I think they are a good idea. I installed the avs one on my 2011 that I bought in August only because there were some rock chips on the tip of the hood that the bug deflector now covers
Go with Toyota, OEM! Installing mine this weekend.
If you never intend on using a car wash its fine. I got mine free(dealer tossed it in) and when I went to install, even with the mylar protectors those clips will eat through the tape and paint. Secured in my garage one can make it move easy and see what would happen. Took it off and tossed it. Got a weather tech (made by and same as AVS) and it sees a car wash at least once a week without issue
My 2020 TRD Off Road Premium is equipped with an OEM deflector.... installed at the port. I like it. It will protect the hood from rock chips.
As mentioned above the mounting clips rest on protective clear adhesive tabs stuck to the hood. I've not seen any movement of the tabs and have no concerns. Keep in mind truck only has 800 miles on it so my opinion may change! :yo:
Now I'm not sure if I go OEM, AVS, or nothing at all... Which ones DO NOT use tape? Has anyone had issues with the paint if you've ever had to take it off and replace it or if you got tired of it?
As mentioned above OEM uses tape. But it’s a fairly thick material. It’s serves as paint protection.
AVS is crap, or at least the one that I got was. It made contact with the top of my grill, and started rubbing paint off. Also made it slightly harder to shut the hood because of that. I didn't have this issue when I first installed it, but I guess it just flexed/deformed over period of time and weather.
I just took the OEM Toyota bug deflector off my 2008 (been on there at least since 2012, when I bought it) and it had caused some paint damage where it rubbed on the leading edge of the hood.
Yes, I think we will just leave it be for now, due to possibility of future paint damage should we ever decide to remove it.
If rock chips bother you, have some PPF installed, every 5-10 year replace it as it wears. I installed PPF my black sports car, replaced it at the 5 year mark, paint looks like new.
tuṣṭāva
