It’s getting addressed moving forward. If you already have yours they will work with you direct on a solution. I stand by my opinion that they are easy to work with, they redesigned this in less then six hours (size of panel was the original issue, new panels will be tiny bit smaller. Same wattage).
Maybe I missed this amongst all the pages in the thread, but what's the wattage output (given ideal conditions of course) of the three panel set?
Update on my end, fried my Jackery power station by plugging it directly into the panels (prolly cuz I have them wired in series). Will try to figure out a way to charge it by plugging into the power controller even though it’s redundant.
This is my fault. They recommend parallel. I did series b/c don’t have to use bigger gauge wire and series has better chance of “delivering usable power in cloudy conditions” as explained to me by someone smarter. I might switch it, not sure yet….
Skipped the center panel until I get the new one.
what did you tape or glue with?
haha i should have thought of that and saved money on the vinyl parts.0.7 mm VHB, no vinyl, straight on the paint. The tape is run along the entire outside edge of the panels to hold them completely flat against the hood. I also added two strips in the middle to hold it away from the paint a bit and prevent rubbing in the center (sorry no install pics). It is entirely more than I need to hold them in place (VHB is insanely strong stuff) but it's best to run it entirely around so there's no gaps. I've worked quite a bit with VHB so I'm not afraid of the removal process if I do ever need to pull them off, already did it once with these as I wasn't entirely happy with my first shot at placement. VHB removal is not what I would describe as a good time but as long as you're patient and let the adhesive remover do it's thing it's pretty straightforward. If I was planning on selling ever I might have wrapped it first but idc, this thing was pretty pinstriped already, not that it really shows in the pic.
