How do you get to the park lights? (2005 T4R)
ahhweewee
I have the 2005 SR5. I have not been able to figure out how to remove the parklight bulb without taking out the entire headlight assembly. My hands are way too big for either side.
Do I have to remove the entire assemby? How do you get that bulb out?
The following is taken from my Haynes Repair Manual for the 2003-2009 T4R:
The parking light bulb sockets are located in the outer, upper corner of the headlight housings.
These bulbs are difficult to access with the headlight housing installed, but they are accessible.
To remove the bulb socket from the headlight housing, turn it counterclockwise and pull it out.
It is not necesary to disconnect the electrical connector unless you are removing the headlight housing assembly.
To detach a bulb from the socket, pull it straight out.
