Hi khrisg76,
Everything whiskycop said is correct. When I removed mine (2012), I believe I removed all of the lamps from the "Bezel" first.
I remember that the nuts were on "Extra Long" studs, so you will need "Extra Deep Sockets" to go over them to reach the nuts.
I also remember that they were UNBELIEVEABLY tight; as if Toyota used "Thread Lock" on the studs, to prevent the nuts from coming loose.
I think there were 3 nuts holding the bezel in place; obscured by the plastic Trim molding & Astetic inner paneling. There are some small (pop-out), removable screw access covers that can be popped out with a tiny, flat screw driver tip.
Like "Whiskycop" said, you need to pull the lamp bezel straight out, and very gently, to insure that nothing gets cracked or scratched.
Good luck khrisg76, and Cheers! Greg, (rigtec)
