How to disable DRL's for an '01
let me go take a picture of mine i disconnected (not cut) under the hood. brb....
so on my 2000 limited directly next to the battery on the fender side there is this box with a black metal cage around it, attached to this box is a gray plug with a few wires coming out of them. i disconnected the plug (2 years ago) and its still working (or not working i should say) great.
perhaps toyota changed stuff because my 01 doesn't have that. the DRL relay is under the dash, like the previous post.
I don't feel comfortable doing anything until someone who has an '01 just like me tells me how to do it. Until then, they're staying on (ughhhh)
i have an 01 and you have to cut the black/yellow wire.
i put a switch inline in case i wanted drls back on
super easy
Now do I need to protect the wire with anything in particular? I don't want it to become a fire hazard.
Yeah, like Rock Slide said, electrical tape, or just do as smkd13 did and put some terminal ends on them so all you need to engage them again is a little wire in the middle.
On 2000 model 4Runners, you can unplug the small black box, near the battery in the engine bay, to disable DRLs.
The DRL module on '01-'02 model 4Runners is located under the driverside dash. You just cut PIN 12, which is a black/yellow wire to disable DRLs. You can always install a switch inline to turn them on and off if needed. Write up is on YT: 2002 4Runner: DRL Disable With On/Off Capability - YotaTech Forums
I have spent the last hour searching and researching this, to try to determine the best way to disable my DRL's.
I really don't want to cut any wires, and I'm not interested in adding a switch to turn the DRL's off and on...
I was all excited about the option of unplugging the box under the hood, but I have a 2001, and there's nothing next to the battery.
Since the module is under the dash on the 2001's, is there anything that I can unplug on the module, instead of cutting?
Thanks for any help!
i guess you could always try to remove the wire from the plug instead of cutting it.
but why go to the trouble when cutting is so much easier
i wired in a switch just in case i ever wanted them on again
or just crimp on a male and female connector if you need it hooked up again
You could always "attempt" to remove the wire from the drl module itself, but for what it's worth, cutting the wire is much quicker; Like OU said, just crimp on a male and female connector for later use. Takes all of 2 mins to do that.
So what years have the box under the hood?
And it seems like everyone wants to disconnect the DRL's/.
Holy thread revival... this was like 4 years ago. I definitely just snipped the cable and was done with it. I haven't looked at it since. So yeah...
Yeah I did the same, not sure why people are hesitant to snip the wire compared to unplugging it.
Much better with them off.
delislerebecca
