How To Fix your Heater Controls (With Pics!!!)
Bill_Dunnigan
Does your heat / AC only work on high? Heres how you fix it.
In most vehicles with multiple manual fan speeds, the manufacturers regulate the voltage going to the motor by way of a resistor. By putting different values of resistor before the fan motor, they can limit the amount of voltage the fan sees. This is all fine and dandy until your fan motor starts getting clogged up with pine needles or whatever and draws more current through the resistor pack. more current means more heat which means bye bye fan speeds. The reason the fan still works on high is because the fan is seeing the full 12-14 volts from the battery un-interupted because there is no resistor needed for high speed.
Now that you know why it breaks, let teach you how to fix it!
Step One: Buy a replacement resistor pack from your local toyota dealer or online. The dealer sells the part for about $35, and i have seen it as low as $10 online. I just went with the Toyota dealer, because they had one in stock and its only $35! Here is the new part.
IMG-20120124-00136.jpg~original
IMG-20120124-00137.jpg~original
IMG-20120124-00140.jpg~original
IMG-20120124-00141.jpg~original
Step Two: Look Underneath the passenger glove-box. Right up front you will see the Resistor pack, or at least the plastic part of it where the harness plugs in. Remove the Harness, Simply squeeze the connector and shimmy it outta there!
IMG-20120124-00145.jpg~original
Step Three: Unscrew the two Phillips head screws that hold on the resistor pack. The bottom one can be accessed with a regular long screwdriver with the glove box closed. The top screw can be accessed two different ways. You can either use a 1/4 inch ratchet with a socketed Phillips head attachment, or you can open the glove-box and squeeze the inside of it to pull it down further and then you will be able to access the screw with the screwdriver! whew!!!!....that was a long run-on sentence!
Step Four: Remove the resistor pack by pulling it straight out, you might nedd to wiggle it a bit to get it out. (might come out in pieces from heat failure).
IMG-20120124-00149.jpg~original
IMG-20120124-00150.jpg~original
As you can see from the picture above, the metal pins are shot! one of them broke a solder and the whole ceramic heat sink is cracked and toasted!
Now, take a flashlight and look inside the cowling (hole that the resistor pack came out of) and make sure there is no debris in there! mine had quite a bit, so I vacuumed it out. I recommend you do the same.
IMG-20120124-00147.jpg~original
Step Five: Reinstall the new resistor pack in the correct orientation. Be-careful, they can be quite delicate. If it breaks while putting it in, you'll have to buy a new one, because it will surly fail again if it looses some of its heat-sink. Don't forget to plug it back in!
Good Luck, Enjoy!
While this has been covered before, I will say that your picture of the location is one of the better ones. :)
There's also a third way to get to that resistor - remove the screws that hold the bottom bar under the glove compartment, and the whole glove compartment drawer just sort of falls out of the way, then it's very easy to get to.
You had a TON of debris in there, though - I had a few drops of condensation and a bit of dust and that was it.
if your fan "bearings" are squeeky or noisy, you probably have something (like a pine needle or dirt) stuck in there. Mine also does this, and it is more noticeable at the lower speeds. I'll look into a complete rebuild of the fan and post pics up later or in another thread.
