How-to: replace your rear-view mirror with a frameless one
engineeer
I wasn't a big fan of the shape or design of the stock rear-view mirror, so I replaced it with a Gentex Series 8 Frameless auto-dimming mirror. It offers just a little more side-to-side viewing range, but top to bottom is about the same.
It's pretty straightforward, but does require buying a connector if you want to be able to swap back to the stock one in the future. Otherwise, you can ignore buying the connector and solder the correct wires directly together. In that case, the black and white wire from the headliner area is ground and blue is power--connect black/white from car to black of new mirror and blue of car to cream/pink of new mirror.
If you reverse these or short them you'll blow the 10A "ECU-IG NO.2" fuse in the driver's wheel well area and your window's will no longer roll down. There's an extra under the hood. Don't ask me how I know this.
Edit: [MENTION=51186]philsey[/MENTION] made a good suggestion--unhook the battery before you do this.
Final product:
Looks nice! When I test drove the new Camaro I remember thinking "that rear view mirror looks sweet.."
My mom's Lexus has a similar frameless rear-view mirror that I really liked, which spurred this change. I drove her car recently and realized that her frameless one has more of a frame than this Gentex one I bought.
thats one nice mirror! i wonder if there is a better fitting matching crimp connector. Probably way bigger though.
The connector I put up is the correct mating connector--no idea why Toyota picked it as they only use 2 pins. They could have used a much smaller connector.
Nice Mirror Mod!
And the replacement mirror is height adjustable just like the stock mirror?
...I like how the stock mirror can be tucked way up, almost to the top of the windshield.
Nice Mirror Mod!
No, unfortunately it is not height adjustable. I didn't use that on the stock one, so I don't miss it.
ghengiskhan
